06-25-2009, 10:51 PM | #1 |
72 Chevy truck 4 inch lift question on brake lines
I had posted a long time ago when i started this project but im wondering if someone has a part number for longer brake lines for a 72 chevy truck with 4inch lift it seems like the stock ones will be a little short. Thanks for any help
06-26-2009, 05:41 AM | #2 |
Re: 72 Chevy truck 4 inch lift question on brake lines
You can take your hoses from the mounts in the frame.Kit`s come with extension brackets that sre easy to make or rig something up.I don`t know a part number.4wd suppliers sell braided 4-6" lift hose kits.But,the one I bought had the wrong end at the axle on the rear.I ordered a longer one from Inline Tube.Know exactly what you need when ordering.The do OEM-spec duplicates.They`ll do custom.But,you need to know exactly what you need different or the guy will be crappy.
06-26-2009, 11:33 AM | #3 |
I don't have the number but you can buy replacement rubber lines from Napa that are longer than stock. If you want to go that route I would have the parts guy pull the replacement hose then ask him to look thru the hoses for a longer one with the same ends.
Or go aftermarket. I run Earls brand steel braded hoses. You can get them in many differnt leghts. I bought mine from a local speed shop.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 06-26-2009 at 11:33 AM. |
06-26-2009, 11:45 AM | #4 |
Ok Thanks for the info they dont look like they need to be alot longer but looks like if you could tear them off pretty easy thanks
06-26-2009, 11:11 PM | #5 |
I used a 74 K-10 with 4" lift kit from Russell for my 59 since it uses 74 axles that are equivlent to a 4" lift to fit the 59 springs. If I remember right the stock ones are 18" and the ones I got were 22" (braided SS, DOT certified). I called the help line to make sure the fitting would work, they arrived and bolted right in. I think they have kits in 2" length increments. I looked and the kit no is 695730 it has 3 hoses. They list it for 73 up, nothing for 72 but call them they probably have something that will work. Here is link to the site and page:
http://www.russellperformance.com/mc...es_truck.shtml
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
