Old 07-01-2009, 12:47 PM   #1
67 c10 guy
67 c10 guy's Avatar
Spindle Question?
How do you tell the difference from a drop spindle and a stock height spindle? All help is appriciated.
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 07-01-2009, 12:55 PM   #2
SCOTI
SCOTI's Avatar
Re: Spindle Question?
Dropped spindles will generally have the spindle hub higher on the body of the spindle & the spindle hub for an OE unit would be located closer to the bottom of the spindles body. Make sense? Another suggestion is most mfr's will stamp p/n's on their respective parts. If there are any numbers, google the number & see what you get.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-28-2009, 03:29 PM   #3
kvn1011
Kvn1011
kvn1011's Avatar
ok, i was wondering with a 72 c10
i have been reading that Z'ing the frame 3 inches will allow you to lay frame on 24"wheels or 30" tall tires,
now my question is, will three inch drop spindles do the same, without Z'ing the frame??
kvn1011 is offline   Reply With Quote
Old 07-29-2009, 01:42 AM   #4
kvn1011
Kvn1011
kvn1011's Avatar
3inch Z and 3inch drop spindles??
Old 07-29-2009, 09:16 AM   #5
SCOTI
SCOTI's Avatar
At that tire height, no, you can't lay frame w/a stock front suspension & 3" drop spindles. You can't lay frame w/a 3" 'Z' & stock spindles.
You need the 'Z' & the spindles (or a Dropmember & spindles).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-29-2009, 04:35 PM   #6
kvn1011
Kvn1011
kvn1011's Avatar
Thank you!!
thats what i was wanting to clarify,
after a month or so i will start on my 72
still studying and learning from you guys, thanks again!!
drop, spindle, stock
