Motor Mounts Chevy Truck
Can someone identify the year of these mounts? I thought they were 72's. Some say they are 73s and up.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Motor Mounts Chevy Truck
Definitely 73 and up.
x2
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
The frame that I bought as (67-72 Short bed) would have been a 73 or later. These mounts came from that frame, so what is the difference between those frames and will the cab and other body parts fit, if that was a 73 or later?
Under Construction
some people install the '73 up mounts on the 67-72 frames.... can you post some pictures of the frame, and we can help you identify. Added a couple of pics of 72 only BB mounts.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 07-14-2009 at 05:03 PM. |
Picture of the frame.
Thank you for the pictures, now I understand. I have seen several listings of 73s being represented as 72s.
Look closely at the pictures that my67truck posted. The 72 only big block mounts have one raised ridge on them, the 73-87 mounts have two raised ridges. That's how you can tell the difference.
Your frame looks like a 68-72 unit. I am basing it on two things. 1) I believe I can see the crossmember for the trailing arms in the edge of the picture. 72 was the very last year for coil rear suspension 2) a 67 frame wouldn't be dimpled for the power steering box like yours is.
Here's a better picture of the rear of the frame.
Under Construction
68-72 for sure.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#11 | |
