07-22-2009, 06:43 PM | #1 |
High Hump Trans Tunnel Cover??
I might be in need of a high-hump trans cover for a little extra trans to floor clearance in the cab of a 64. I know they were made for the 67 & later years, what about pre-67?
07-22-2009, 10:39 PM | #2 | |
Re: High Hump Trans Tunnel Cover??
The high hump tranny covers were available in the '60-'66 Chevy/GMC trucks, that were equipped with the factory SM420 or SM465 4-speed floor shift transmission. If you are converting from a factory low hump tranny cover, you will need the corresponding front cover, that is factory spot-welded to the firewall. I have these items, if you are still looking for them. |
07-22-2009, 10:44 PM | #3 |
60-66 Nut
Yes scot there are both high and low trans covers. I have a high one if you are in need. However it does have the hole for the 4 speed.
07-23-2009, 04:41 PM | #4 |
Is there enough material to bolt 'both' pieces in vs. one being spot welded & the other a bolt-on?
07-23-2009, 05:14 PM | #5 |
yes you can bolt both pieces in, just need the clip nuts and drill some holes....that is how ours was bolted in....I have one also (with the hole for the shifter) that may be for sale, gotta check with someone first.....
CHEVY ONLY |
07-23-2009, 07:45 PM | #6 |
I have spoken w/a couple of individuals concerning these parts but haven't got confirmations yet. I definitely do need one 'set', so if you read this & have 'em, let me know.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-23-2009 at 07:46 PM. |
07-24-2009, 05:16 PM | #7 |
Ok, I have the set. I honestly dunno what it is worth. I would be willing to do some swapping if you have anything interesting. I also might be able to bring it down to you or meet you somewhere in the middle if you are interested.
CHEVY ONLY |
07-24-2009, 08:20 PM | #8 |
here are some pics
I started a WIW thread HERE are you in need of a good granny 4 speed also? I have a complete SM465 if so.
CHEVY ONLY Last edited by joe231; 07-24-2009 at 08:25 PM. |
08-04-2009, 02:35 PM | #9 |
Thanks joe231. Couldn't have asked for an easier transaction.
08-04-2009, 08:32 PM | #10 |
If I am going from the factory 3 on the tree to a 200R tranny will the factory hump work and if not what hump needs to go in there?
08-04-2009, 10:33 PM | #11 |
200r4's are the same physical size as th350's so either trans tunnel 'hump' should work. I swapped in an aftermarket front crossmember & I'm using a 700r4 trans & thought the extra clearance was a good idea.
08-04-2009, 10:35 PM | #12 |
Thanks to you too, SCOTI
linkbelt......the 3 speed trans hump should work fine for your 200R4, as SCOTI has stated.
CHEVY ONLY Last edited by joe231; 08-04-2009 at 10:36 PM. |
08-05-2009, 06:42 AM | #13 |
Thank you guys
08-05-2009, 10:11 PM | #14 |
MI '69
Since it looks like you guys are all taken care of, I'm going to hi-jack this thread.
I also am in need of a high hump tunnel. Its for my 67 and I'm trying to fit a ZF 6S-650 under it. Its basiclly the 6spd manual out of the HD Silverados a couple years back.
1967 Chevy (Project Frankenstein) 1973 K5 Blazer |
08-06-2009, 08:15 AM | #15 | |
1. you are in the wrong section...this is the 60-66 section...and 2. you can't post a wanted to buy post as a non-site supporter. it is against forum rules http://67-72chevytrucks.com/vboard/a....php?f=34&a=17 for $25 a year you can become a site supporter http://67-72chevytrucks.com/vboard/payments.php
CHEVY ONLY Last edited by joe231; 08-06-2009 at 08:17 AM. |
08-06-2009, 08:24 AM | #16 |
it's just $25.00
08-06-2009, 08:26 AM | #17 |
on that note, Joe how do I remove the Jr. member BS under my name?
08-06-2009, 08:28 AM | #18 |
MI '69
oops sorry bout that. disregard the post then.
08-06-2009, 12:21 PM | #19 | |
scroll to the bottom and click save changes.... Done
CHEVY ONLY |
08-06-2009, 01:11 PM | #20 |
08-07-2009, 01:21 PM | #21 |
I also need a high hump for a '65. Looking for both pieces as pictured to complete my dropmember installation. Please pm with price and shipping to 29067.
Thanks Chris |
08-07-2009, 02:14 PM | #22 |
You might be able to split the existing tunnel cover to clear. I just felt this was the cleaner option for my DM install. Pics for Joe231 by this weekend....
