Old 01-04-2010, 01:02 PM   #176
VA72C10
VA72C10
VA72C10's Avatar
Re: 1969 Short Wide
Just an FYI...we used Tri-plus (keyparts) rockers on my truck and they fit great w/out any cutting. The ones that were on by the PO obviously didn't fit right so we took them out. Expected to cut these but didn't have to and they look good with the door in place.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-04-2010, 01:13 PM   #177
1sik52
Re: 1969 Short Wide
Just a little FYI...LMC sells Tri-Plus (Keyparts) and they dont fit worth a crap on my blazer either!!!
1sik52 is offline   Reply With Quote
Old 01-04-2010, 02:25 PM   #178
VA72C10
VA72C10
VA72C10's Avatar
Re: 1969 Short Wide
Most of the tri-plus components have fit very well for me. However, one notable exception was their lower door patch which was HORRIBLE. But i'm sure it depends on the truck/blazer as each one is slightly different and the QC at the factory wasn't that good honestly...
Old 01-04-2010, 02:32 PM   #179
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
The door gaps around the rocker were good and over all the panels fit in there with only a few mods but the real problem is here in these pics:
I'm sure there are problems with all the aftermarket sheetmetal parts. I just want you guys to see what I am talking about. These edges "should" be flush.
I think I can fix it just matter of cutting and pulling and rewelding.
mcbassin is offline   Reply With Quote
Old 01-04-2010, 02:44 PM   #180
0331grunt
Now what??
0331grunt's Avatar
Re: 1969 Short Wide
this is the part of my build that I am not looking forward to... I will be asking a lot of questions when this comes up! I don't think I would have noticed it. At least not until it was too late
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 01-04-2010, 02:47 PM   #181
VA72C10
VA72C10
VA72C10's Avatar
Re: 1969 Short Wide
Old 01-14-2010, 03:00 PM   #182
chevy88
chevy88's Avatar
Re: 1969 Short Wide
So what is your next step on this truck?
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 01-14-2010, 03:52 PM   #183
brian69longbed
brian69longbed's Avatar
Re: 1969 Short Wide
i left my factory rockers and patched as needed... should've bought new rockers. would much rather have these fitment problems. looking good!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
Old 01-14-2010, 05:30 PM   #184
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Next step will be to finish roughing in the cab. By that, I mean I won't do any finish body work until it is mounted on the frame. I plan to clean the other side of the shop and rearrange things so we can fit the frame inside and start rebuilding suspension, brakes, and rear diff.
Thanks Brian,
I could have gotten away with trying to straighten the driver side but the passenger lower pillar was shot. We are like 95% rust free on the cab. Still have a little area on the passenger kick panel. Still lack major body work on the cab corners where it has been mistreated or dropped when moving it around.
Right now I am focused on getting my lower unit fixed. I had to pull the prop shaft and replace the water pump. Hope to get all the parts in for it by next week. Here are some crappy pics of it I took with my phone:
Old 01-14-2010, 05:35 PM   #185
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: 1969 Short Wide
I can store the boat and one camaro here, so it helps you with shop space....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-14-2010, 05:35 PM   #186
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Hey if you do some boat repair you may want to talk to HighPerf4X4. He was having an issue with his boat, and could use some advice. The place that worked on it for him didn't help him out much.
JohnC is offline   Reply With Quote
Old 01-14-2010, 05:51 PM   #187
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
You must have a big shop buddy! Yes I need to get rid of all the junk that is filling up space in my shop.
John,
I only do boat repair when I tear it up ...dang it! I would be glad to offer my 2 cents to help if I can. I hate to have people wrenching on my stuff if you know what I mean....even oil changes.
Old 01-14-2010, 06:08 PM   #188
my67chevytruck
Under Construction
Re: 1969 Short Wide
not a big shop just helping you gain space
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 01-14-2010, 07:09 PM   #189
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Scott
93 crew cab build
Project 62
Old 01-14-2010, 07:21 PM   #190
brian69longbed
Re: 1969 Short Wide
DIY all the way i say
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
Old 01-15-2010, 12:22 AM   #191
highperf4x4
Re: 1969 Short Wide
I shelled the gears in my lower and upper unit last summer. It's a Mercruiser Alpha1 outdrive. Got any tips for that repair?
highperf4x4 is offline   Reply With Quote
Old 01-15-2010, 12:33 AM   #192
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I'm not too sure about that one, if the case isn't damaged you should be able to do it yourself. I'm not too sure about whether or not it requires backlash or shimming with the gear sets. That is probably like setting up a rear differential. You may be able to pick up an outdrive complete and just bolt it up and go? Really depends on what you have for a budget.
This is where I buy my parts:HERE
There prices are about as cheap as you can get. I really hate dealing with H and H. Baats are bottemless money pits and they really never pay you back.
Old 01-15-2010, 05:27 PM   #193
highperf4x4
Re: 1969 Short Wide
Check this out. Complete Alpha1 replacement drive by SEI with 1.47 V8 gear ratio with 3 year no questions asked warranty for 1200.00
http://www.sterndrive.cc/Merchant2/m...lphaSterndrive
Old 01-15-2010, 05:30 PM   #194
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
CHEAP! go for it!
Old 01-15-2010, 11:07 PM   #195
nuke1
nuke1's Avatar
Re: 1969 Short Wide
Holy crap, i can not believe that i have not posted in such a long time, anyways, glad to see so much work done on the truck, and good choice on the copper primer, that is the best stuff on the market to this day, i know, i tried everything out there, worth the money trust me,. I know all about the boat thing, i tore the leg off of my silver line, hit a rock pennisula on the lake, ouch. anyways, just have to let you know, everything looks great and remember aftermarket is aftermarket for a reason, you have to FIT it, not them. Also i sure could use a camaro, let me know if you got a spare, or a 70 chevelle, Later.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-15-2010, 11:28 PM   #196
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Nuke! Sorry to hear about you messing up your boat too. How's the projects going? I just got the prop and the prop shaft back from the shop. Supposed to be straight less than .002" runout and the prop looks new. Still
waiting on the rest of the parts to come in next week to rebuild it.
Hope to get back on this project next week, we are going to some salvages tomorrow to find a radiator and some other parts for my kids 86. I'm also going to the scrap yard to try to find some 18-20 sheetmetal for the firewall. I have been working with 22 gauge and it's too thin for the angle detail. If I decide to sell one of the Camaros you will be in line too.
Got most of the parts for the lower unit
Old 01-16-2010, 09:33 AM   #197
nuke1
nuke1's Avatar
Re: 1969 Short Wide
nice shiney parts, and ya, 22 gauge is way too thin, you should use 20 gauge normally and 18 also. I use both on my things. Sure wish my prop was that shiney. Did you change the pitch on it, more torque or speed? With mone i needed the torque.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 01-16-2010, 10:33 AM   #198
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
No, It was set up perfect before, the prop was worn and had some dents alon the edges...you know how they get beat up on rocks. Anyway, they welded the whole perimeter and made to the oem specs. We'll see how it runs next week hopefully.
Old 01-20-2010, 01:04 AM   #199
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Well, I'm still waiting on parts to come in for th outboard so I took one last stab at making the wire channel angle detail. I picked up some thicker sheetmetal at a the scrap yard, I think it is 18 gauge. Anyway, I got tired of making templates and taking them to work to cut my sheetmetal so I made a little table for my bandsaw. Now I can cut sheetmetal at my shop! I then started fabbing the pieces for the angle (2 left and 2 right). I was able to roll the inside radius around my argon bottle to get the shape close. I then tacked it all in, then staggered my welds about every 2-3 inches till it was done, then ground the welds and primered, it will still require some hammer and dolly work but that can take place on the frame. It took around 4 hours total. Hope to get my lower unit parts in tomorrow or thursday so I can get that out of the way. Next on this will be the cab corners, they need straightened and possibly some rust repair, even though I haven't found any, that doesn't mean it's not there.....on to the pictures:
Bandsaw before the table added
Plate cut for table
Table welded and installed
Tacking the angle detail
More
Ready for welding solid
More
Completely welded
Welds ground smooth
Primered
Old 01-20-2010, 01:05 AM   #200
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
