Old 07-26-2009, 08:20 PM   #1
Hertzdaddy
Factory transmission cooler
I have a 73 2wd Jimmy that I'm building and when it came to me the radiator was not installed. The two cooler lines from the tranny had been cut. The Jimmy has what looks to be the factory auxiliary trans cooler as well as a tranny cooler built into the radiator. The lines from the auxiliary cooler come through the front support on the driver side. Is this the factory location? How do the lines from the auxiliary cooler route to the tranny cooler lines on the pass. side of the radiator?
BTW, a build thread is coming soon.
Thanks.
Hertzdaddy is offline   Reply With Quote
Old 07-26-2009, 10:31 PM   #2
Hertzdaddy
Re: Factory transmission cooler
Never mind. I'm pretty sure its the AC condenser after all. The Jimmy didn't come with factory AC but now I remember the PO said he was going to put a system in.
Ok then, out it comes. No AC for me.
Old 07-27-2009, 08:43 AM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Good luck with it man..
tvblazer78 is offline   Reply With Quote
