Old 07-28-2009, 07:29 AM   #1
MTtruck
MTtruck's Avatar
How hard is it to fix a leaky rear main??
Its on 68 GMC short box with year 72 3/4 ton running gear.
Paul"Give old trucks a second chance"
MTtruck is offline   Reply With Quote
Old 07-30-2009, 10:44 AM   #2
Dying2Live
Dying2Live's Avatar
Re: How hard is it to fix a leaky rear main??
If if was me, I'd pull the engine. It's something that could be done in a day. I pulled my last engine out of my '68 and it took about 2 hours. You should be able to start early one morning and get it all put back together and running by that evening, if you have the tools.
Dying2Live is offline   Reply With Quote
Old 07-30-2009, 11:05 AM   #3
MTtruck
MTtruck's Avatar
Does it require any specialty tools?
Old 07-30-2009, 11:08 AM   #4
faribran
No special tools... DYING summed it up very well.
faribran is offline   Reply With Quote
Old 07-30-2009, 11:13 AM   #5
MTtruck
MTtruck's Avatar
Thanks guys! ill give it a go next week some time.
Old 07-30-2009, 11:24 AM   #6
Dying2Live
Dying2Live's Avatar
As long as you have a means to get the engine out (cherry picker) and an engine stand to use while you're working on the engine, you should be in good shape with a socket set, gasket scraper (oil pan gasket) and possibly a seal removal tool for removing the rear main. Good luck, and don't be afraid to ask questions, these guys are awesome at not being jerks like some of the other forums that I frequent.
