Old 08-05-2009, 07:58 PM   #1
Oklahoma
S-10 steering column in a 62
I was wondering if a S-10 steering column would work in a 62 so I had to find out today. Here is the end result. I havent wired it up yet, but it is secured in the truck.
Oklahoma is offline   Reply With Quote
Old 08-05-2009, 07:59 PM   #2
Oklahoma
Re: S-10 steering column in a 62
Woops
Old 08-05-2009, 10:51 PM   #3
mike73
mike73's Avatar
Dangit!!!!! I just GAVE one of those away!!!!
mike73 is offline   Reply With Quote
Old 08-07-2009, 09:55 AM   #4
lo72
Truck Junkie
lo72's Avatar
NOW THIS IS SWEET..... I just happen to have an s10 col and a c-10 tilt like this....any pics or advice on what mods and how you got it to fit? I'm looking at installing one in my 70 c-10...thanks
lo72 is offline   Reply With Quote
Old 08-07-2009, 04:22 PM   #5
Oklahoma
It was'nt hard, I used a combination of both support brackets, just alittle imagination and it went together pretty sweet, if you want i could take some pictures of underneath if you want
Old 08-07-2009, 08:59 PM   #6
lo72
Truck Junkie
lo72's Avatar
that would be great any pictures would be great
Old 08-07-2009, 09:48 PM   #7
Bears63
...just another truck junkie..
Bears63's Avatar
Heck yeah, post up pics!!!! I want to know more too, that column looks right at home in there. How about connecting it to the steering box? Have you gotten that done yet?
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-08-2009, 09:18 AM   #8
Oklahoma
OK the first picture is on the Driver side, and I used a section of the original support bracket, and the highbeam swith pluged right in ( altho I dont know if it works yet, because the cab is off the frame right now) the second picture is of the passenger side of the column, and the upper part is original column support and the lower part is from the new column, just cut and weld. this column is in there tight, dosent budge what so ever. As far as bolting it up to the gear box, like I said the cab is off the frame right now, but i dont fore see any problems with that.
All I have to worry about is the wireing, so if anyone has a wire scamatic for a 62 c-10 and a 93 blazer that would be great.
Old 08-08-2009, 10:07 PM   #9
lo72
Truck Junkie
lo72's Avatar
These pics are sweet. Thanks for taking the time...what kind of bracket are you using at the firewall?
Old 08-08-2009, 10:51 PM   #10
bubba327
HOW long until spring??
bubba327's Avatar
Looking good . Are you planning to use the hand E-brake again? My 3 on the tree column comes out tomorrow and a tilt column from a automatic Nova is the option A. Thanks for the thread and pictures. Keep us posted on your progress
Did you have to trim any of the plastic from the column? Any trimming of the dash metal?
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 08-09-2009, 04:01 AM   #11
Oklahoma
using the stock bracket at the firewall, it bolts right up.
Old 08-09-2009, 06:54 PM   #12
lo72
Truck Junkie
lo72's Avatar
Thanks...now a new piece to the project, If i don't stay off this site I may never finish it!!!!! Thanks again!
Old 08-09-2009, 11:00 PM   #13
bubba327
bubba327's Avatar
What are your plans for an Emergency brake?
Old 08-10-2009, 05:22 AM   #14
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: S-10 steering column in a 62
Not Bad!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 08-10-2009, 09:40 AM   #15
Oklahoma
I dont plan on reusing the e-brake, I have never used it any way, besides it on e-bay right now.
Old 08-11-2009, 03:08 PM   #16
Oklahoma
Well I just finished wiring it up and it went smoother than I expected. I have the dimmer hooked up, blinkers, wind shield wipers, and the ignition switch hooked up in around 2 hr's. The only thing I dident hook up is the flashers, and I refuse to believe that a chevy will break down and leave me stranded.:
