Old 08-07-2009, 07:42 PM   #1
TXBowTie
Question Questions from the new guy
Hey guys. I just bought a '75 long bed C10, 2WD, Silverado and discovered this site while trying to figure out how best to approach my new project
I have found some pretty good info here, but would like to ask a few questions:
My truck doesn't have a sway bar. If I find a factory sway bar setup from a different 73-87, it will bolt right onto my '75, right?
My back bumper is pretty bent up, and has welded-on custom brackets. I think I have learned that any 73-87 fleetside bumper (with matching factory brackets) will bolt right on (but only early ones will match my front bumper), is this correct?
My Truck was originally a 454 (per the VIN), but now it has a 350. I noticed it has a TH400, and an over-sized radiator top bracket/ fan shroud. Are there other things "special" that I will run into when ordering parts, because this truck was originally a 454?
My two-tank bed is pretty beat up, if I swap it to a fleetside long bed from an 81-87 (with the square filler-cap doors) will it bolt right on? Will the body lines match? Are the only parts I need the bed, tailgate, and fuel tank filler tubs?
Thanks so much for your help guys, hopefully I will now enough to answer questions myself here in the future...
Wayne
TXBowTie is offline   Reply With Quote
Old 08-07-2009, 08:15 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Questions from the new guy
Congratulations on the purchase AND finding the site.
Yes! And to take it a step further, you can look all the way to 91 on Burbs, and C-20/C-30's. What you will need to know is that the bushing clamp "stands" are rivited to the frame.
Correct! Also Blazer/Burb bumpers are the same. The inner brackets from these trucks won't work but the outers will.
Those are the items that I know of for sure. There may be other's.
Correct! Body lines are the same, trim is different
Wayne
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-07-2009, 08:16 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the beds will interchange but you will need to change the fuel filler hoses. thats how i did my 76 which is basically the same truck
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
454, bed swap, rear bumper swap, sway bar
