Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-09-2009, 04:36 PM   #1
Resmondo
Dash Cluster problem!
ok when the headlights are off the blinkers work fine. when i turn the headlights on they both lights up constant but only the left blinker will work and the gauge lights do not come on and the water temp guage will only work when the headlights are on. Ive checked the circuit on the back and all the connections seem fine.
Resmondo is offline   Reply With Quote
Old 08-09-2009, 04:42 PM   #2
jay6891
Car Knocker
jay6891's Avatar
Re: Dash Cluster problem!
Recheck your grounds. Clean terminals and try again. Sounds like that may be the problem
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 08-09-2009, 05:27 PM   #3
Resmondo
all grounds seem to be good. i did find that the cluster lights are on. the blinkers are the only problem. when the lights are not on they work fine just when i turn the lights on they both come on. the left will blink very slowly and the right will just dim
Old 08-09-2009, 09:18 PM   #4
69nova
On our year model trucks, when you have a light out, the dash signal indicator stays lit to let you know that you have a light out. As said previously by others a ground will give you the same symptoms as a light being blown or not grounded.
69nova is offline   Reply With Quote
Old 08-09-2009, 09:35 PM   #5
Resmondo
so make sure i have a good ground to the cluster?
Old 08-10-2009, 09:57 AM   #6
69nova
When I say light out, I mean any one of your signal lights and on my truck thats 4 per side because my sidemarkers blink as well. The driverside lights will cause the left turn signal indicator to stay on when you pull your lights on and passenger=right. Make sure that you have a good ground to everything. I had a similiar problem and I had to add a ground strap from the bed to the frame.
Old 08-10-2009, 06:37 PM   #7
Resmondo
ok just check all the lights all the turn signals work and all the sidelamps, brake lights and headlights. I do not have the reverse lights right now would that cause the problem
Old 08-15-2009, 12:50 PM   #8
KEL
72 GMC
KEL's Avatar
ttt
KEL is offline   Reply With Quote
Old 08-15-2009, 01:49 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
side markers, tail lights, and backup lights would not do this. This feature is to allert you that the turn signal is not working. Frequently, if the front parking light/turn signal light assembly isn't grounded very well, it'll back feed and light up the indicator... seems more common on 69 and 70 models.
Old 08-15-2009, 08:39 PM   #10
Resmondo
wow grounding the lights did the trick.. I didnt have the original light harnesses so i put some others that just plugged in...shoulda known they had to be grounded thanks. now my guage lights work too!
Old 08-15-2009, 11:49 PM   #11
Longhorn Man
sweet
morbid curiosity... what year truck?
Old 08-16-2009, 10:34 AM   #12
Resmondo
its a GMC 1970 1500
http://www.cardomain.com/ride/3205069
I have pictures of both before and after on there
Old 08-17-2009, 09:27 AM   #13
KEL
72 GMC
KEL's Avatar
just went through the same issue with
my 1972 GMC. backfeeding through the
temp gauge annd high beam indicator.
both would pulse with the turn signal,
and the temp gauge would climb in
increments until burried. i was missing
a screw holding the printed circuit to the
back of the cluster.
all set now. so easy once you know
where to look.
Old 08-17-2009, 09:39 AM   #14
Resmondo
yea i wouldof never expected a non grounded light. My temp guage and fuel guage still arent working. i think i just dont have the temp guage hooked up right because its an aftermerket guage, but my fuel guage just stays at the bottom. is that a bad guage or sender? how can i check that?
blinker, cluster, water temp, wiring problem
