08-19-2009, 02:58 PM | #1 |
350 to 700R4 swap
I have a 1972 k10 that I will be swapping out the th350 for a 700R4 on it.
I will be going with the spacer from A & Reds, grinding off the shafts and moving my 205 TC back a couple of inches. My questions are: A) do I need a 4X4 700R4 or will a 2X4 work? B)I read that 86-91 years 700R4 will work best, is this correct. |
08-19-2009, 07:21 PM | #2 |
Re: 350 to 700R4 swap
anyone?
08-19-2009, 07:36 PM | #3 |
olblue60@aol.com just did this swap.pm him,he can give you the low down on everything you need to do.
Yes you need a 4x4 trams case,86,87 have a k case witch is stronger.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
08-20-2009, 09:29 AM | #4 |
I put a 700r4 in my Blazer, I got the trans from Bowtie overdrive, and had them install a conversion output shaft that let me bolt it directly in place of the th350. I opted to leave the transfercase in place, and moved the engine ahead.
08-20-2009, 06:22 PM | #5 |
member
I am doing the same now to my 67 panel. If you are going to buy a ready to go 700r4, you will need the spacer. This means that the 205 will need to be moved back causing driveshafts to be cut and legthened, your column shift linkage will need to be modified, transfercase shifter will need to be modified to come up in the right place and the pivot on the frame for the column shift will need to be relocated. I had my trans built with the adapter shaft, moved my engine forward 1 7/8 inches and everything else lines up. Just my .02 cents, but the moving forward seems alot easier and even allows a little more clearance at the distributer. All you need to do is drill 8 new holes at the engine cradle. Good luck on your build. You will need to add a 4th gear trans lockup kit and summit racing has a geometric compensater for the downshift (detent cable) that goes on the carberator butterfly. The shaft is made by advance adapters but is actually $20 cheaper at Summit. Any Questions gimme a call !
John 202-213-3657 (eastern standard time here)
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 08-20-2009 at 06:29 PM. |
08-24-2009, 08:31 PM | #6 |
After reading your replies I going to move my engine foward instead and have the shaft swap on the 700r4 instead of the spacer. Thank you guys for the replies, Love this forum!
08-24-2009, 10:55 PM | #7 |
member
Its easier than I had expected. Cost a couple of bucks though. I have about $1650 into the swap. Good luck!!
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
08-25-2009, 07:24 AM | #8 |
Yea but you had a kick a** trans built.
08-26-2009, 05:20 PM | #9 |
why do you have to change the transfer case adapter
08-27-2009, 01:05 AM | #10 |
member
08-27-2009, 11:18 PM | #11 |
The t-case adapter for the 205 will bolt to a th350 or a 700r4, so you don't have to change it.
The out put on a 4x4 700r4 is 2 inches longer than the th350s so if a person isn't or can't change to the conversion output then you have to use a 2 inch spacer between the trans and the adapter.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
08-28-2009, 01:19 AM | #12 |
member
P.S. I just had to purchase an adjustable throttle cable /carb bracket. This also has the hookup for the TV cable. Summit has it for $8.95. I tried the other cables and it seems this setup will work out the best and uses the original 72 4x4 cable. I installed this setup into my 67. I'm not sure what to do with the earlier linkages for the gas pedal.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 08-28-2009 at 01:23 AM. |
