Old 08-29-2009, 10:52 PM   #1
Brewski*
Brewski*'s Avatar
Edelbrock 1406 Spring Kit Installation?Z
When I go off road my 1406 runs like crap so I got a spring kit from edelbrock. Just a box a springs? Any idea what to install where to make the carb off road ready?
Right now it totally sucks~!
Brewski* is offline   Reply With Quote
Old 08-29-2009, 10:59 PM   #2
Mudder
Mudder's Avatar
Re: Edelbrock 1406 Spring Kit Installation?Z
Hey Brew..........welcome back. if we don't get an answer in a day or so I will move this to Engine.
Mudder is offline   Reply With Quote
Old 08-30-2009, 09:52 AM   #3
Brewski*
Brewski*'s Avatar
Hey Mud,
Thanks for the welcome back it has been forever. My truck runs perfect except for offroading then the carb loads up and floods out.
Brew
Old 08-30-2009, 11:11 AM   #4
'63GENIII
'63GENIII's Avatar
Mine loads up while idling in the driveway and floods out all the time if I let it run for more than a minute. My driveway is @ 25 degrees. I've called Edelbrock to ask about the spring kit but both times ( I called twice because I couldn't believe what they were telling me the first time ) I was told that the kit was to help with the flooding being caused by bouncing while wheeling and not for constant steep terrain operation. Had I looked into it a little before I bought, I would have found that these carbs are no good for use on anything other than flat ground. I love the way that the Edelbrock runs on flat ground but I should have bought a Holley, or better yet get the 6.0 liter installed!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-30-2009, 02:29 PM   #5
Mudder
Mudder's Avatar
Hollies are no better unless you put out for the off road carb.
Old 08-31-2009, 10:27 AM   #6
martindc1
The only springs I know of on Edelbrocks are the step-up springs on the metering rods. In this case under low vacuum conditions (=higher load), they cause the metering rods to move out of the jets thereby making the mixture richer.
Unless your spring kit is for the float.
I'd go to their site and download the manual.
After re-reading your posts it sounds as if you all and I are talking about 2 different things, though I would still make sure they didn't sell you the step-up spring kit.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 08-31-2009, 11:02 AM   #7
Mudder
Mudder's Avatar
Gonna move this over to engines.
Old 08-31-2009, 11:30 AM   #8
Jim_PA
I think a Qjet is in your future
Jim_PA is offline   Reply With Quote
Old 08-31-2009, 12:29 PM   #9
cableguy0
you need spring loaded needles and seats. the same would apply for a holley. i know they are about 35 bucks for a holley. i got rid of my edelbrock long before i spent any more money on that pos. mine would load up in a hard corner flood and stall. that was always fun in traffic
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 08-31-2009, 01:42 PM   #10
70rs/ss
70rs/ss's Avatar
Yep off road needle and seats are to prevent the bouncing. As for the flooding, you can check your float level as a high level will allow the fuel to pour over and flood it.
70rs/ss is offline   Reply With Quote
Old 08-31-2009, 03:05 PM   #11
turp mcspray
turp mcspray's Avatar
On my rock crawling blazer, I started out with an Edelbrock. I did the spring loaded needle and seats, lowered the floats, dropped the fuel pressure, (I usually run 1.5 to 2 pounds when in the rocks)etc. This carb just flat out DID NOT like angles. I then tried a 780 holley that I had. Spring loaded needle and seats, float whistles, hose with a vent connecting front and rear. Worked GREAT! I have since put the 406 into my chevelle, and threw a mild 350 into my blazer, with a stock Quadrajet. In my opinion the Q-jet is THE best carb for wheeling. I have seen rigs keep on running while standing straight up in the air. At that angle I don't thing you would have any oil around the pickup so it probably doesn't matter anyway! LOL! I have tried em all on the same rig and the Q-jet is king in the rocks!
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
