Old 08-30-2009, 04:35 PM   #1
minime's 68'
241 C Transfer case help!!
I'm doing a vortec swap in my 68' Chevy LWB 4x4 with a 4L80E. I need help with the shifter and the linkage for the transfercase. Has anyone done this? I can use all the help I can get!! Thanx
minime's 68' is offline   Reply With Quote
Old 08-30-2009, 09:38 PM   #2
Re: 241 C Transfer case help!!
The transfer case should not be hard to make a hole for in the trans hump.Were you able to hook the transmission up to the`68 column linkage?
Old 08-31-2009, 10:01 AM   #3
minime's 68'
ya i got an after market linkage for the trany. When I bought the truck they had a floor shifter in. But I wanted more room on the floor so we hooked the column shifter back up. Any Ideas on the linkage for the 241 C?
Old 08-31-2009, 08:05 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The 241 uses the same linkage as a 208. you should be able to pick up a shifter for either from a salvage yard...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
