Old 09-15-2009, 07:57 PM   #1
1950 GMC
1950 GMC's Avatar
S-10 Conversion Questions
1. For the guys who built there own cab mounts are any of you guys using the orginal factory front bed mounts? I read the AG instructions and it said to cut them off, and I just wanted to confirm.
2. Does anyone have good mock up photos of how they did the motor mounts, and raditor mounts? I'm planning on installing a flat fire wall with no notch for the distributor if I can get away with it. I hope I dont have to use a *****in' firewall as I personally like a flat smooth firewall better. JMO...
3. What is the difference between the GMC and Chevy front fenders for a 1950? I would like to purchase some new front fenders and I found some Chevy fiberglass ones for a good price. I 'm going to be using the GMC grille no matter what so can I use the chevy fenders?
4. Last question. When I got my truck the front was completly disassembled and I was wondering what parts am I missing? I will list the all stuff I have. 2front fenders, hood, outer grille (goes around the grille), and the grille. Thats it...
Thanks for the help everyone.
Thanks,
Garrett
My 1950 GMC Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=351867
My 1950 GMC Photobucket Account:
http://s565.photobucket.com/albums/ss95/1950GMC/
1950 GMC is offline   Reply With Quote
Old 09-15-2009, 08:47 PM   #2
rhodog77
rhodog77's Avatar
Re: S-10 Conversion Questions
50 GMC,
I will chime in with my 2 cents worth.
1. The factory bed mounts will need to be removed. You could fab your cab mounts to match the bed mount height but that would leave your cab really high off the frame. Your better off mounting the cab at the height you want and then make new bed mounts.
2. Im in the process of setting my motor in. I will post pix on my thread (50 5 window ss10 swap) as soon as I get it in. I will have tons of pix when Im done.
3. Not sure if there is a difference in the chevy/gmc fenders. Im sure someone in the forum will know.
4. Not sure what your plans are with the truck but if you are going back stock here is what your missing. Inner fenders, upper and lower hood latch plates, radiator core support, splash apron, fender braces and inner fender braces.
Hope this helps.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 09-15-2009, 11:23 PM   #3
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
1. I will refer you to my build thread, it shows how I mounted my cab. rear, is original shackle mounts, front is the rear s10 cab mounts trimmed and swapped sides. http://67-72chevytrucks.com/vboard/s...0&postcount=26
2. If you want to have a flat fire wall you probably don't need to use the s10 v8 conversion kit, that should give you enough fire wall clearance, but then you might have issues with radiator clearance.
3. Not sure.
4. rhodog77 has it covered.
Good luck with your build.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 09-16-2009, 12:41 AM   #4
OrrieG
OrrieG's Avatar
All I can address is #4 and recommend you get a factory assembly manual. It will show all the little parts and pieces you will need and order of assembly. Hopefully your project came with a box of misc stuff and and well labeled baggies of bolts and small stuff.
OrrieG is offline   Reply With Quote
Old 09-16-2009, 12:14 PM   #5
1950 GMC
1950 GMC's Avatar
Thanks guys appreciate the quick response...
Thanks,
Garrett
Old 09-21-2009, 04:30 PM   #6
texas56
texas56's Avatar
I also have a ton of pics I can send you. I just painted my chassis this weekend and assembled it. I used the factory mounts but I had to knoch the running board brackets.
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 09-23-2009, 08:38 AM   #7
c10addict
c10addict's Avatar
I followed Jeffs51's plans for cab mounts... Check my build thread for pics..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 09-23-2009, 10:35 AM   #8
1950 GMC
1950 GMC's Avatar
c10addict, Looking good and a great referance.
Thanks,
Garrett
Old 09-23-2009, 10:45 AM   #9
c10addict
c10addict's Avatar
Here is a link to Jeff51's build... Great info...
http://67-72chevytrucks.com/vboard/s...92#post3533592
