Old 09-17-2009, 08:38 AM   #1
lookingtobuy
lookingtobuy's Avatar
Spark Plug Wires?
Good morning all,
I am still working on the little extras on my Blazer, even though it's still for sale.
I have added a Pertronix Distributor and Flamethrower Coil, my question is
Anybody have any leads on preassembled, good quality plug wires, that
are the stock length and stock ends?
Thanks for your help... I'm trying to keep as original as possible
lookingtobuy is offline   Reply With Quote
Old 09-17-2009, 09:01 AM   #2
John H.
John H.'s Avatar
Re: Spark Plug Wires?
I used the reproduction wires from one of the electric companies and they fit exactly like the originals in all the correct holders.
John H. is offline   Reply With Quote
Old 09-17-2009, 09:06 AM   #3
John H.
John H.'s Avatar
Name:  GMC restored frame 002.jpg
Name:  GMC restored frame 001.jpg
Old 09-17-2009, 12:39 PM   #4
lookingtobuy
Great PICS!! Do you know the exact name of the company?
Old 09-18-2009, 09:44 PM   #5
Mike C
Mike C's Avatar
Pertronix makes a 7mm set. Also, the Taylor Spiro pros you can get in red or blue.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-18-2009, 11:14 PM   #6
jaros44sr
jaros44sr's Avatar
Originally Posted by John H. View Post
John H. great pics, nice work! Can I get a closer shot of your brackets, where they bolt to the block in the back of the engine. I've looked before on my block, but can't find the spot where the brackets bolt into
I thought everyone was using the 7 MM '74 corvette wires, if you have an HEI
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-19-2009, 01:40 AM   #7
John H.
John H.'s Avatar
I can not remember if it was M&H or Lectric Limited for the wires.
Old 09-20-2009, 08:46 PM   #8
Mike C
Mike C's Avatar
The 75-82 'Vette wires are great for an HEI swap. Order 75 just in case all '74s didn't have HEI. I know in the Camaro the Z/28 did, but the base motor did not until '75.
44 Willys MB
52 M38A1
64 Corvette Coupe
ignition, plug wires, stock
