Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-21-2009, 08:34 AM   #1
franks72
Junior Member
franks72's Avatar
Pressure switch for nitrous bottle heater
I'm installing some new goodies on the truck for the nice fall weather at the track.Hope to see the 11.90s soon with new carb,new converter,and best of all is the nitrous bottle warmer pressure switch from a company called dyno tune, This switch is great,it keeps my bottle at 950psi .This switch is way better than any of the thermal switches I've used.http://www.dynotunenitrous.com/store...p?idproduct=43
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 09-22-2009, 04:56 PM   #2
J_PEPIN87
J_PEPIN87's Avatar
Re: Pressure switch for nitrous bottle heater
Sounds great! So what kind of carb, and converter are you going with now?
J_PEPIN87 is offline   Reply With Quote
Old 09-23-2009, 07:19 AM   #3
franks72
Junior Member
franks72's Avatar
I'm going with a 4150 hp 750 cfm mech sec holley and a JEGS Street/Strip XHD 10'' Torque Converter Stall Speed: 2900-3200 RPM. The old carb was a 700 mech sec and the converter is a 12'' 1800 stall. The changes should help my 60ft times and I will be able to launch it on the juice. Does any one know the breaking point of the stock driveshaft ?????
Old 09-23-2009, 11:45 PM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I have a 3/4 ton 2 piece that I rebuilt & had balanced. My truck scales out @ just under 4100lbs with me and 20gal of fuel over the rear. I launch @ 3600 on trans break. Motor makes just over 600HP So the stock ones can handle some abuse.
68 C-10 KID is offline   Reply With Quote
Old 09-25-2009, 04:42 PM   #5
J_PEPIN87
J_PEPIN87's Avatar
Originally Posted by franks72 View Post
i'm going with a 4150 hp 750 cfm mech sec holley and a jegs street/strip xhd 10'' torque converter stall speed: 2900-3200 rpm. The old carb was a 700 mech sec and the converter is a 12'' 1800 stall. The changes should help my 60ft times and i will be able to launch it on the juice. Does any one know the breaking point of the stock driveshaft ?????
oh hell yeah that converter is going to make a difeerence, going from 1800 to 3000, a big difference!
Old 09-26-2009, 04:24 PM   #6
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
that pressure switch is pretty neat
i cant tell the difference between my stock converter and my 2800
how do you tell the difference
be sure and post some videos
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
