Old 01-14-2003, 11:55 PM   #1
Power Trip
Got Caddy?
Power Trip's Avatar
Question caddy 500 swap ????
I am wanting to install a 500 caddy along with the tranny at one time. My truck has a low hump cab and a manual crossmember. Is it possible to install the auto tranny crossmember before the installation of the motor. The reason I ask is that the cab is not bolted down and I'm able to remove it completely. I figure it would be easier to put it in. Would I mount it in the original holes from the factory or would it have to be relocated ? Also the motor mounts, can I use the ones off of the caddy or should I buy the kit from MTS? If the weather would cooperate I could have a caddy in the driveway by the end of the week so probably more ?????s will follow. Man I hope I made cents Jim
1969 c-10 swb fleetside with dreams
of a caddy 500 Bagged shaved and rollin' on 18's
Future bumper sticker.
Looks like a chevy, runs like a caddy!
Power Trip is offline   Reply With Quote
Old 01-15-2003, 01:02 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Jim, click on the caddy link in my signiture.
As for your crosmember question....depends on your tranny.
I say hang the combo where you plan on putting it, and then see where everything needs to get bolted.
Old 01-15-2003, 10:02 AM   #3
Power Trip
Got Caddy?
Power Trip's Avatar
sorry I meant to ask you about the motor mount towers is it possible to use the caddy towers or buy them from mts? Well then I will go ahead and mount the cab and and slide it on in. Thanks Andy I've read that site about 10 times always seem to miss something. Have you gotten any further with yours? Jim
Old 01-15-2003, 12:28 PM   #4
Earl Junior
Cadillac power
Earl Junior's Avatar
I'd say the cab deifinitely needs to be in place. Firewall clearance is a big issue and would be nearly impossible to figure out without the cab in place.
I don't think the auto crossmember sits in the same place. At least it didn't when I did the swap. I mounted the motor and the placed the cross member where it needed to be.
I followed longhornmail's install pretty darned closely, and it worked well for me.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 01-15-2003, 12:42 PM   #5
71MoneyPit
MPG...hmm..more like GPM
71MoneyPit's Avatar
check out the thread in the engine forum "Cadillac Engine", there is a lot of information on there from various people that are doing this swap, it really helped me out.
(Looking for 67-72 shortwide or shortstep bed)
71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires
85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one.
71MoneyPit is offline   Reply With Quote
Old 01-15-2003, 12:43 PM   #6
71MoneyPit
71MoneyPit's Avatar
longhornmail- where did you find that avatar
Old 01-15-2003, 09:57 PM   #7
Longhorn Man
I mounted my engine with teh tranny still in place, that way I knew I wouldn't be needing to move anythign or get my drive shaft chopped.
As for towers, I used what I had on hand...'72 big block towers. I hear the 73 and up are similar...and since they are not a one year only item, the 73 and up would be a bit easier to get your hands on. I just drilled some holes in the towers, and moved them way up on the chassis.
I've had that butt head giff for so long, I can'r remember where I got it.
Old 01-15-2003, 10:09 PM   #8
Power Trip
Got Caddy?
Power Trip's Avatar
well thanks for the help guys. I have been searching threw the posts to see if I missed anything and I did. So hopefully i'll have the cab mounted tomorrow and pick up the caddy saturday. Its a 76 deville w/500 auto,and power everything. Trust me I will take plenty of pics too of the swap. Jim
Old 01-15-2003, 10:15 PM   #9
Longhorn Man
And I would love to put it on my site.
Just hope you don't meat me to the tire smoke...one on here already has.
I can't beleive he fololoed my instructions on my site, but beat me.
bummer.
Old 01-15-2003, 10:27 PM   #10
Power Trip
Got Caddy?
Power Trip's Avatar
well if i beat you to it i will save the tire smokin shots for when your done lol. Well your not that far behind are you?
Old 01-15-2003, 10:30 PM   #11
Longhorn Man
Its all bolted in...but not wired plumbed, no drive shaft (need u-joints and carrier bearing) and all that happy jazz.
Old 01-16-2003, 11:57 AM   #12
71MoneyPit
71MoneyPit's Avatar
Thumbs up
well hopefully in the next few days if it is not too nasty outside i might take the Money Pit around the block for the first time to make sure the gauges are working and get the fluid running through the tranny,( it's been sitting for a while)so far i have had it in and out of the garage a few times, but i haven't actually driven it or opened 'er up (just manifolds no exhaust but so far it seems to run pretty damn good, it chirps the tires when you put it in gear(its on gravel though) but it seems REALLY torquey
the only thing i have'nt tested yet is the elec. kickdown switch on the carb linkage, does anyone know what the correct throttle setting on the switch is. ( is it 3/4 throttle or almost full throttle?)
