Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-22-2009, 02:01 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Radio Buzzing / Interference / Noise
I finally got around to turning the radio on the other day and now it makes and awful buzzing noise when the truck is running. Doesn't matter if I play a cd or listen to the radio. It does NOT do it when the truck is turned off and the key in the acc. position.
My first thought was the new plug wires I bought did not have the RF shielding, but upon further investigation the box they came in states they are RF shielded.
What now?
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 09-22-2009, 02:31 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Radio Buzzing / Interference / Noise
Do you have an RF blocker installed on the radio? I remember having this problem with a vehicle and after installing an RF blocker the noise went away.
Aftermarket radio or stock?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-22-2009, 02:46 PM   #3
rwolf9653
more ideas than money
rwolf9653's Avatar
Sounds like you are getting feedback from the alternator.
Does it get higher pitched when you accelerate? Check or change your grounds on the radio and engine to see if it gets better.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 09-22-2009, 03:17 PM   #4
Devil Pup
Devil Pup's Avatar
you mentioned cd player, are you running an after market head unit and possibly an amp to speakers or a sub? If so just change the remote wire to the opposite side of the cab that the power wire is running. it will stop it for sure.
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 09-22-2009, 03:20 PM   #5
6600DURAMAX
I did change alternators but all I did was get rid of the old one because it was only a 60 amp and replaced it with an identical 100 amp.
What is a RF blocker and where does it install, the radio never had one before??
It is an aftermarket Alpine head unit
thanks guys
Old 09-22-2009, 03:21 PM   #6
6600DURAMAX
Yes Devil, I am running a sub with a remote wire, but I do not follow what you mean by run it to the opposite side of the cab????
Old 09-22-2009, 03:28 PM   #7
Devil Pup
Devil Pup's Avatar
ok, basically when you ran the amp. . most likely its under the seat? you had to run a power wire to it from the battery and the remote wire to it from the deck. usually if you put the remote and the power down the same side of the cab "driver side or pass side" it will pick up interference and that's what your hearing.
Old 09-22-2009, 03:34 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it's more likely to be a bad, or more acuratly a 'dirty' ground.
moved to audio
Old 09-22-2009, 03:38 PM   #9
Devil Pup
Devil Pup's Avatar
Ya i would say check the ground first regardless, thats the simplest fix. but i am pretty sure its the wiring
Old 09-22-2009, 11:28 PM   #10
AceX
>130dB Moderator
AceX's Avatar
Ground loop noise most likely. x2 check the ground and add a second to make sure. You can also add a noise supressor to the wiring for the radio.
Some alternators are very noisy. If you can, try and find one made by Powermaster. They don't cost a ton and don't put out a whole lot of noise either.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 09-23-2009, 12:30 AM   #11
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Sounds like RF noise to me, not a bad ground. (although a bad ground can cause this) As mentioned earlier you need an in line filter installed between your power source and your head end. The filter is a Capacitor-based device that will pass DC but filter out RF AC. Cost about 6 bucks at most auto parts stores and I think even "Radio Crap" carries them.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 06-01-2016, 09:36 AM   #12
colgad
colgad's Avatar
Fixed my radio buzzing with replacing the capacitor in my brand new HEI Distributor. The capacitor is the square red block, some HEI's have the can style. Never the less the noise is GONE!!!!
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
