Old 05-21-2002, 10:07 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Post Putting in a new Power Steering pump
I bought a remanufactured power steering pump (with resivour) for my truck. It is a '72 C10, with a 350 and stock accessocry backets. How should i go about putting it in? Will i have to bleed the air out of the PS system when i am done, and if so how will i do that? Thanks for the help!
Lucas
"Another proud owner of one of the coolest trucks ever built"
drop_shift@hotmail.com
My Daily-Driver: '72 Chevy LWB Custom/10. Rebuilt 350, roughly 300 HP thanks to a 204/214 duration cam, Edelbrock Performer intake and 1406 carb, headers, and 40 seires Flowmaster mufflers. Ochre with a white top. Lots of fun .
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 05-21-2002, 10:19 PM   #2
slam33
slam33's Avatar
Post
If you haven't done it pull the bracket and mount the pump to it then remount the assembly. Hook up your hoses, If you didn't empty the gearbox then you should be able to refill the pump and just turn it lock to lock a few times to get the air out. Then recheck your leval.
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 05-21-2002, 10:30 PM   #3
Zkast
Zkast's Avatar
Post
Here is what I have found to work the best without damage to the pump.
After you get it all installed and ready to start, fill the resevior to the full mark. Start the engine for 2-5 seconds, check/fill the level again. Start and let run for 10 seconds or so(if you hear the pump whine, shut it off) refill the fluid.
At this point you should have most of the air out, now crank the wheels side to side a few times to clear the lines then recheck the level once more (engine off of course)
Keep in mind, most remanufactures require you to flush the system before installing the new pump. Remove all fluid.
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Webmaster/Team owner
www.zkast.com
Garrett - Olathe, Kansas
[This message has been edited by Zkast (edited May 21, 2002).]
Zkast is offline   Reply With Quote
