Old 09-25-2009, 05:38 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
dana 60
How can I easily tell if its a dana 60 front end and what would one that is in working order be worth?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 09-25-2009, 05:42 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: dana 60
depends. there were 2 versions i believe, a balljoint type and king pin type.
kingpin is worth more i believe.
good working order ive seen 800-1200
balljoints i think go for 500-900 id say.
driverside drop were fords and passenger side drop were gm/dodge
there should be a stamp on the pumpkin ear, on the front of the axle nearthe bottom. usually driver side. should have a "60"
d44 has "44" stamped
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-25-2009, 05:46 PM   #3
Wildstreak
Wildstreak's Avatar
Re: dana 60
thanks man I plan on going around to a couple local scrap yards this weekend and wanna see if I can find a decent working dana 60.
57 chevy 4x4
68 burb 2wd:
Old 09-25-2009, 05:51 PM   #4
70 beast
Certified Hobbiest
70 beast's Avatar
Re: dana 60
no problamo.
ive been scouring ALL the local pick n pulls and local junkyards in northern cali for about 2 years now in hopes to find that dimond in the ruff.
my jimmy build
Old 09-25-2009, 05:51 PM   #5
whiskeydented
whiskeydented's Avatar
Re: dana 60
Easiest way on a gm 60 is to look to see how the passenger spring is attached, 1 or 2 u bolts see photo.
whiskeydented is offline   Reply With Quote
Old 09-25-2009, 05:54 PM   #6
70 beast
Certified Hobbiest
70 beast's Avatar
Re: dana 60
military issue trucks are the real winners. they came stock with 1 ton axles and 4:56 gears and sometimes a posi. locker in the rear with matching gears.
my jimmy build
Old 09-25-2009, 06:08 PM   #7
Wildstreak
Wildstreak's Avatar
Re: dana 60
I know I always am looking at the military pick-ups on ebay just because of their drivetrain. Well I had a 85 blazer 2 years ago with 1 ton running gear and a 454 I sold it to a friend who then inturn sold it to another friend that let it deteriorate and blew the 454 and got the truck taken of the road do its rust and is now sitting in a local scrap yard. Im hoping the running gear is still under it. fingers crossed!
57 chevy 4x4
68 burb 2wd:
Old 09-28-2009, 02:07 AM   #8
BurnoutNova
BurnoutNova's Avatar
Re: dana 60
I saw about 4 military K30's at the dealers auto auction the other day. They looked like they were mid 80's trucks. I just drove by it I wish I knew how much they went for. I'd think those ones would be best anyway they dont get abused as badly as a work truck might.
BurnoutNova is offline   Reply With Quote
Old 09-28-2009, 02:54 AM   #9
2tons of fun
Re: dana 60
4 easy ways to tell a d60 from a d 44/10b.
1 d60 has the above mentioned 2 studs and 3 u bolt.
dodge d44's had a similar setup but they are completely different out side of that.
2 4" locking hub. the d44/10b hub is only 2.5" in diam.
3 kingpins, gm d60 only had kingpins, no balljoints, ever, never happend, never made, do not exist.
4 second bump on cover. the d60 has a pronouced bump on the cover were the fill plug is located. the d44 is on a smooth portion and the 10 is egg shaped.
how to tell a dodge d60 from a gm one.
1 the shock mounts, a dodge d60 has a single flat bar that stand straight out off the tube, gm uses a stamped steel one mounted on an angle.
2 the d side spring perch, the dodge is cast iron and about 2.5" tall. the gm one is stamped steel and about 1.5" tall.
3 the brake lines, dodge will have a hard line mounted to the axle with short soft lines. a gm will have long soft lines going to the frame.
modern d60 vrs older d60s'
all modern and ball joint d60 are drivers side carrier.
a kingpin dodge and gm are passenger side and only ford is driver side.
most modern d60s have unit bearings and vac operated hubs,
king pin will only have manual locking or rarely the auto locking like a 10bfront.
2tons of fun is offline   Reply With Quote
Old 09-28-2009, 03:46 AM   #10
Dooley
Dooley's Avatar
Re: dana 60
Most of what has been posted here is correct. I've had 1 or more Dana 60 equipped GM trucks continuously since 1977, all 1 tons. I currently have 2, again.
The 1 ton 4x4's from 1977-79 had full time hubs, regardless of transmission. I know this made no sense but, was true. I installed Husky Selectro hubs on mine.
Starting with my 1980, they have had Spicer Lockouts.
Dooley is offline   Reply With Quote
Old 09-28-2009, 04:13 AM   #11
2tons of fun
Re: dana 60
Old 09-28-2009, 08:15 AM   #12
duallyjams
duallyjams's Avatar
Re: dana 60
My local yard always has d60 laying around GM and Dodge.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-28-2009, 02:10 PM   #13
70 beast
Certified Hobbiest
70 beast's Avatar
Re: dana 60
yah, cali just sucks in general for trying to find one in a junkyard.
my jimmy build
Old 09-28-2009, 08:22 PM   #14
ghettoluxury
ghettoluxury's Avatar
Re: dana 60
try ohio u can find on here to save your life
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 09-28-2009, 11:49 PM   #15
BurnoutNova
Re: dana 60
Not as many people needed 4x4 heavy duty trucks where the weather is nice! There's tons of D60's around here but there still not cheap. I bet up in Minnesota, North Dakota and Wisconsin there's lots of K30's in the junkyards.
When I was up in northern Minnesota on a fishing trip I swear every towtruck I saw was a 4x4... Not very common in SE Nebraska to see 4x4 Medium Duty wreckers!
Old 12-23-2009, 08:56 PM   #16
Wildstreak
Wildstreak's Avatar
Re: dana 60
went to another scrap yard today and asked if they had any d 60's and they said they had some and I told him I wouldnt mind 4:56 and he said he would get back to me. he called later while I was out and said $1800 for a front and $500 for a matching rear. Im not sure if he meant rebuilt or what but I spit up my drink a lil when I heard that considering I see m1008 going for $2-4k. Ill have to call back and see what the exact details are but I know I wont spend that on it.
57 chevy 4x4
68 burb 2wd:
Old 12-24-2009, 01:07 AM   #17
2tons of fun
Re: dana 60
anyone that buys them for that is an idiot.
call doug.
www.extremeaxlesales.com
Old 12-24-2009, 01:15 AM   #18
Wildstreak
Wildstreak's Avatar
Re: dana 60
Thats what I thought, like what did he look up the most expensive price then list it at that. Im goin to call tomorrow if theyre open and see what the scoop is.
57 chevy 4x4
68 burb 2wd:
Old 12-24-2009, 01:31 AM   #19
2tons of fun
Re: dana 60
the most expensive stock d60 i know about is from boyce equpiment, they are $2500 and are NEW crate axle surplus.
doug typicaly sells chevy front for $850+/-
Old 12-24-2009, 02:23 AM   #20
Wildstreak
Wildstreak's Avatar
Re: dana 60
Yea theres one on ebay that says its a n.o.s for 1800 still in the crate.
57 chevy 4x4
68 burb 2wd:
Old 12-24-2009, 09:06 AM   #21
duallyjams
duallyjams's Avatar
Re: dana 60
That is crazy. It would be cheaper to drive to Md to purchase one.
James
IG duallyjams
Old 12-24-2009, 09:49 AM   #22
b454rat
Re: dana 60
Jeez I have one for $500 and can't sell it. I dont' know how or who the idiot is that would buy one for that price. Even the Boyce ones are ridiculous. It doens't cost that much to rebuild one, not hard either.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 12-24-2009, 03:52 PM   #23
whiskeydented
Re: dana 60
I bought 3 this summer. One I paid $300 drw, so so shape also got the matching c&c rear with that one for that price. One srw, $600 excellent condition. I also got another srw that I traded a 14 bolt and dana 44 for. Sometimes its even cheaper just to buy the whole truck.
Old 12-24-2009, 05:23 PM   #24
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: dana 60
Do you know much about the Super 60's found in the 99 up F-450's? I know a little about them but am wondering if they are used in anything else as in ag or man lift or trenching equipment?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-24-2009, 05:42 PM   #25
b454rat
Re: dana 60
The Stupid Duty's aren't as desirable as the older ones. They have unit bearings and balljoints that aren't as strong as kingpins. More expensive to go crossover. The centers are pretty much the same, still high pinion, but that's aboot it.
