Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer II
Old 10-06-2009, 07:43 PM   #1
chevy2racr
Broke Liltte B@stard
chevy2racr's Avatar
my 99 V-8 swap
had 2.2, bearings went out, mocking things up... got Trans-Dapt 9906 mount kit and Hedman shorty direct fit headers #69520 kit. massaged the fire wall some on the pass. side to clear flange. looks like drivers side it good. steering shaft goes through the drivers side header.
thoughts? advice? pointers?
TRUCKS
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 Custom/10 Deluxe 454 A/C and posi
71 Custom/10 Step Side major tear down... on a 69 SWB frame
99 S-10 5.1L SBC 700R4
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 10-06-2009, 08:43 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: my 99 V-8 swap
Nice pictures!
gchemist is offline   Reply With Quote
Old 10-07-2009, 09:11 AM   #3
bigbadjohn84
Re: my 99 V-8 swap
sweet. Ive always wanted one of those light weight dummy blocks to do mock ups. just could never justify the extra dough. will follow
bigbadjohn84 is offline   Reply With Quote
Old 10-07-2009, 08:14 PM   #4
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
set the tranny in to see how it'll look/fit gotta build a cross member to get me some room for exhaust. but all looks promising.
TRUCKS
Marshalltown, Iowa
Old 10-07-2009, 08:15 PM   #5
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
4 degrees of slope in the tranny, I think that'll work
TRUCKS
Marshalltown, Iowa
Old 10-07-2009, 08:22 PM   #6
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
some exhaust fabbin pics...
TRUCKS
Marshalltown, Iowa
Old 10-08-2009, 04:16 PM   #7
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
tranny crossmember
TRUCKS
Marshalltown, Iowa
Old 10-12-2009, 08:55 AM   #8
Myself
Re: my 99 V-8 swap
Go ahead and trim the ears off the trans bell. If you ever need to unhook the headers it will be easier. Those two studs hanging from cab floor make a nice place to mount a driveshaft safety loop. Pull your carpet back and mount some of that heat reflective stuff under it from the firewall back about 1/2 way on the floor. The headers will cook your feet on long trips. Don't cheap out on your cooling system, go aluminum water pump and radiator. You'll be glad you did. That's all I can think of right now.
Myself is offline   Reply With Quote
Old 10-18-2009, 08:50 PM   #9
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
some more progress
i gotta get a radiator, alternator, A/C compressor (Or a delete pulley for now) but its coming together
TRUCKS
Marshalltown, Iowa
Old 10-19-2009, 05:35 AM   #10
68C15
68C15's Avatar
Re: my 99 V-8 swap
a word of advice on the AC compressor. do NOT buy reman. you might as well get a used one. same quality and cheaper. I recommend getting the Sanden replacement unit. I did mine and will never look back. get the compressor kit. it comes with ICE32, the compressor, correct oil, accumulator, and all O rings/seals.
I got mine from T & A service here in SF. ~$275
68C15 is offline   Reply With Quote
Old 10-20-2009, 06:55 AM   #11
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
i was thinkin pulling from the junk yard for now, get the compressor the hoses...
TRUCKS
Marshalltown, Iowa
Old 10-20-2009, 03:27 PM   #12
clinebarger
clinebarger's Avatar
Re: my 99 V-8 swap
chevy2racr. Your not concerned about emissions regulations? one day emissions testing WILL be nationwide.
1970 Chevy LWB A/C P/S Tilt, 350, Edelbrock heads, RPM intake, 650 holley, 700R4
1939 Buick model 40 special 248 inline 8
1985 Chevy Suburban 3/4 Ton with a 2004 5.3/4L60E
1997 Dodge Ram 3500 ext. cab Cummins/NV4500HD
2004 Chevy 1500 crew cab 5.3/4L60E
clinebarger is offline   Reply With Quote
Old 10-20-2009, 05:47 PM   #13
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
well theres no big hurry here...
TRUCKS
Marshalltown, Iowa
Thread Tools
Display Modes
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
