Old 10-27-2009, 05:08 PM   #1
truckincurt
10 bolt
will a 10 bolt rear end hold 500 ft lbs of torque
diy or die
truckincurt is offline   Reply With Quote
Old 10-27-2009, 06:38 PM   #2
turp mcspray
turp mcspray's Avatar
Re: 10 bolt
If built well. There are a lot of guys running single digits in the 1/4 mile, with a 8 1/2" 10 bolt. Not that it's the ideal way to go, but it can and has been done.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-27-2009, 07:29 PM   #3
LONGHAIR
Re: 10 bolt
The real question is: "Will your tires or suspension?" seriously...if you are not "hooking up" the strength of the rear end doesn't really matter that much.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-27-2009, 08:50 PM   #4
Myself
Re: 10 bolt
I agree with the above. Just too many variables. With a locker and 35-15.50 boggers....NO. Open diff and 235/70-15 .....indefinately.
Myself is offline   Reply With Quote
Old 10-28-2009, 08:20 PM   #5
truckincurt
Re: 10 bolt
if i build the 10 bolt its gionto have a detroit true trax and tires are goin to be 10" wide slicks if i can fit them
diy or die
Old 10-28-2009, 08:27 PM   #6
cableguy0
Re: 10 bolt
If your going to all that effort you might as well find at least a 12 bolt to start with. Its a much stronger foundation to start with.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-28-2009, 09:21 PM   #7
orbot
orbot's Avatar
Re: 10 bolt
will 12 bolt and 10 bolt rears have interchangable parts like axles?
orbot is offline   Reply With Quote
Old 10-28-2009, 09:35 PM   #8
cableguy0
Re: 10 bolt
no. nothing interchanges. everything on the 12 bolt is bigger
Old 10-29-2009, 06:37 AM   #9
Blazer1970
Blazer1970's Avatar
Re: 10 bolt
Actually, you can swap the axle shafts between a newer 30 spline 10 bolt and a 12 bolt. They are exactly the same except for the length of the little bit of shaft that extends past the c-clip.
Blazer1970 is offline   Reply With Quote
Old 10-29-2009, 07:16 PM   #10
truckincurt
Re: 10 bolt
is there any way to convert the 12 bolts to 5 lug?
diy or die
Old 10-29-2009, 07:35 PM   #11
truckincurt
Re: 10 bolt
plz disregard last this post
diy or die
Old 10-29-2009, 11:34 PM   #12
Captainfab
60-66 Nut
Re: 10 bolt
If you're talking about the '63-'70 12 bolts, then yes. You can get aftermarket 5 lug conversion axles from CPP, Early Classic, and Summit
Old 10-30-2009, 12:20 AM   #13
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: 10 bolt
My stock, worn out 350 and the 4 speed sheared the right shaft in my 10 bolt. So, I have a 12 bolt now for the sake of a little more strength.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
rear axle
