Old 11-04-2009, 04:12 PM   #1
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
72 Wood Grain Door Inserts in Non wood grain panel OEM or Repro Door Panels
After reading up on it a bit I've decided to have my wood grain inserts restored.
My door panels had been cut out for speakers so they are rubbish.
I'm looking at buying used 72 door panels. They are in good shape, but I don't know if they came from the factory with the Super wood grain inserts.
There is a chrome trim around where the wood grain panels WOULD be, but of course there is no wood grain.
Are these panels compatible with my original factory wood grain inserts?
What about Repros from LMC? I would guess they are rubbish, but maybe not?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 11-04-2009, 05:30 PM   #2
100gold
Re: 72 Wood Grain Door Inserts in Non wood grain panel OEM or Repro Door Panels
I'll try and answer this one for you cedorris.
If the new door panels have the chrome trim they will work with your door inserts.
You'll have to be careful removing your chrome from your old ones. The clips are more like a soldered nail on the back of your chrome strips.
Mine has 2 of the clips (or bendable nails) broken off. I haven't quite figured out how I'm going to fix that one.
Good luck and yes, it's very doable.
100gold is offline   Reply With Quote
Old 11-04-2009, 06:02 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
LMC's are not complete junk, they will work, but they are nowhere near factory looking. They are ABS plastic versus the original aluminum ones, but you can modify non deluxe door panels to put the woodgrain on. Just need to drill holes to put the trim on. I did this on my first truck, with the plain jane 72' door panels and put the woodgrain on them. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-04-2009, 06:36 PM   #4
100gold
Trevor,
He said that the door panels he's looking at already had the chrome strip. Shouldn't it just be a matter of pulling the trim and laying the inserts in and putting his trim back on?
Old 11-04-2009, 08:14 PM   #5
71blksuper4x4
SWB 4x4 Collector
no, I caught that. On another thread in the parts section he asked if any 72' door panel would work. You can use the 72' deluxe panels (scroll pattern w/ chrome trim) which would involve removing the chrome trim delicately and putting the woodgrain underneath it and reusing the chrome trim. Or like I said, use 72' regular door panels (No scroll pattern on them, and drill holes for the chrome trim to be applied and run the woodgrain over it. The latter one was the one I am talking about because you can really use either one, EXCEPT for the new reproduction scroll door panels because they don't fit quite right and normally get out of whack in the molding process. Trevor
TREVOR
Old 11-05-2009, 11:16 AM   #6
cedorris
cedorris's Avatar
Ok, I think I'm getting some good information here.
To summarize:
-Any style of 72 door panels CAN be compatible with wood grain inserts.
-The type with the chrome ring and scrolling is the Deluxe style and these are ALREADY compatible with wood grain inserts.
-Repros don't fit quite right and repro scrolled panels are not compatible with wood grain inserts.
Is this about it?
-Clayton
Old 11-05-2009, 11:28 AM   #7
100gold
Nice job on the summary!
Yep, that's the way I see it exactly.
Old 06-28-2010, 05:58 PM   #8
cedorris
cedorris's Avatar
I am looking for someone to do the restoration of the original woodgrain Instrument Bezel, Glovebox Doors & Door Panels.
Cheyenne Super Man was highly recommended, but his web site is down. Is he still around? If so, what's his contact info. If not, who else would you fellas recommend?
-Clayton
1972, cheyenne, door panels, super, wood grain
