11-13-2009, 11:52 PM | #1 |
POR, KBS, Hammerite and so on
Hi, I'm just looking into painting a frame and was wonder what are some of the best products are.It really needs to be durable considered I live up north in Canada. Long winters with lots of salt and rocks . So ya
11-14-2009, 01:43 PM | #2 |
Re: POR, KBS, Hammerite and so on
you answered your question before you asked it. As long as you stick to a well known product, you'll be fine. POR15 has been around for YEARS and has proven itself time and time again. So has several others.
11-14-2009, 02:54 PM | #3 |
Well I'm not so sure about POR15. I've heard that it takes a lot of prep.I also read the the KBS frame kit is like POR15 on steriods.Any other products that are good?
11-14-2009, 06:20 PM | #4 |
I have had good results from Blue Lightning "Chassis Coat"
http://www.blulightning.com/category/paints/
"Negative people always seem to have a problem for every solution" |
11-14-2009, 07:26 PM | #5 |
How much prep is needed?
11-14-2009, 10:50 PM | #6 |
I sandblasted my frame and then sprayed on the coating. ( It can be brushed or rolled also) It doesn't require any primer , and bonds to any clean surface. It's a very tough coating. I think they said that it was originally desgined to prevent corrosion on offshore oil platforms.
11-18-2009, 03:24 AM | #7 |
Looks great.
11-18-2009, 08:58 AM | #8 |
the whole secret of durable long lasting results oif any paintjob is the prep work the more you do the better the results
11-18-2009, 02:36 PM | #9 |
I used Rust Bullet with great results.
2008 Chrysler 300C 1984 Chevy K5 Blazer |
11-18-2009, 03:10 PM | #10 |
Certified Car Nut
I cleaned and derusted my frame by hand and used SPI epoxy with a single stage black.
11-26-2009, 07:02 PM | #11 |
USMC
The prep for POR-15 can be minimal if you want it to be. Go over it with a wire wheel or cup brush to get the loose junk off, clean/degrease it, and paint it on. You can use metal etch before you paint too. but that's about it if you wish.
The better you prep anything before you paint it the better the final outcome will be. POR-15 is sticky stuff, its been on the garage floor for years(by accident) and I didn't do any prep to the floor at all!! LOL
Semper Fi |
