Old 11-16-2009, 10:55 PM   #1
ripper70
ripper70's Avatar
Lift Question
Does anyone now if 35 x 12.5s will rub front fenders on my 70 K20 with 4 inch Tuff country Lift?
ripper70 is offline   Reply With Quote
Old 11-16-2009, 11:39 PM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Lift Question
from Lake County California! I don't know for sure but if you've got a K20 with a 4" lift I'll betcha you'll be OK.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-16-2009, 11:42 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Re: Lift Question
33 x 12.5's fit on my C-20 with no lift, so I think you'll be fine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 11-16-2009, 11:44 PM   #4
Smallz72project
Smallz72project's Avatar
Re: Lift Question
You should be fine although alot of it depends on the wheel that you are running. Positive verse Negative offset. Are you planning on the lift or are you trying to figure out what will fit on your truck thats already lifted? Can always go into your local tire store and have one test fitted...if not you might look towards a 315/75
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 11-16-2009, 11:50 PM   #5
ripper70
ripper70's Avatar
Re: Lift Question
Actually i Started my restoration and the truck previously had 4 inch block lift and while tearing truck down noticed they had chopped the front of the front fenders a little to get clearance but it was already to late to check. On the web site im ordering my new 4 inch lift it says recommends 33 x 12.5.
Old 11-17-2009, 09:29 PM   #6
turp mcspray
turp mcspray's Avatar
Re: Lift Question
Kinda depends on how you plan on using it. If it's just a street truck, you will probably be fine. I have a 6" lift on my blazer, and even with the lower rear of the fender cut off back to the brace, my front tires hit hard in the rear if the wheels are turned even a little bit. But this truck gets "wheeled".
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
