11-20-2009, 10:50 PM | #1 |
Body swap
So i just got a 69 k20 suburban and i have a guy giving me a c-20 pickup that has an a/c cab. so i was wondering can u put a truck cab and bed on the suburban frame with just bolting on the cab and bed mounts? the suburban has some good rust and the truck has little rust and has a wood bed.
11-20-2009, 10:59 PM | #2 |
I really hate wet sanding!
Re: Body swap
I don't know about the body swap, but you could take the suburban suspension on the truck, I think that would be a little easier to do, especially if you do most of your work by yourself. I would think the burb frame would be different than the truck as far a body mounts and wheelbase. Good luck others will jump in and get you pointed in the right direction.
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
11-20-2009, 11:06 PM | #3 |
Re: Body swap
Moved to 4x4. Check out to see if there is difference in wheel bases first. You will need a high hump for the floor. Compare the frames from the cab back. It may be straight forward, maybe not. Maybe need some spacers or something to get things to line up. Cab forward should be alright. I always tell people to make sure you can get the distributor out before you bolt things down.
11-21-2009, 07:50 PM | #4 |
Sb 400 club
Re: Body swap
Wish the guy who swapped the 327 into my willys wagon heard that. Everything fits good Except you have to pull the motor to pull the dizzy.......
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
