Old 11-22-2009, 12:28 AM   #1
82swampthing
82swampthing's Avatar
parking brake cables
I have a problem , I swaped my 14bolt s.f out for a another one from a 84 k20. now the problem i have is the 82 parking brake cables have brackets with 2 holes in them to bolt on to the dust shield. The 84 has a hole for a connector with the little fingers. i know that the 84 uses longer cables that meet up on the driver side of the frame . my 82 has the cable that goes along the frame on both sides to a mounting bracket on each side.I would change the dust shields but they are bolted and welded to the axle tubes.what do you guys think it the best solution for this.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 11-23-2009, 01:53 AM   #2
82swampthing
Re: parking brake cables
never mind i changed the dust shields.
R.I.P gm 1908-1986
