11-30-2009, 10:08 PM | #1 |
need advice on 53 chevy pickup
does anyone know if a 1989 gta tras am motor trans rearend and frontend will work under my 53 half ton chevy pickup im a newbee and i have achance to get one pretty cheep any help would be great. Thanks:
12-01-2009, 12:49 AM | #2 |
Re: need advice on 53 chevy pickup
as most people will tell you - anything will fit with enough fab work. Measure the track width, measure the distance between frame rails - then make your decision.
If they're close - go for it. I haven't heard of this combo, but that doesn't mean it wont work. The motor will work, as any motor you put in with a grafted front clip will require custom motor mounts. As far as the rear end goes - again, measure the width and the rest is custom fab work... |
12-01-2009, 06:11 AM | #3 |
THanks MrTuucker i apppreciate the info!
12-01-2009, 12:08 PM | #4 |
The front end won't work, but the rest will. They stopped using a subframe in 1981, so if you want Camaro front end go with 1967-1981, but there are other options.
12-01-2009, 09:55 PM | #5 |
Thanks pdw i really dont need to have a camero frontend just hoped i could use it because im buying the whole car . oh well ill find something. Thanks any ideas on my build will be helpful.
12-01-2009, 11:20 PM | #6 |
1978-1987 Chevy Malibu works very well, 1968-1979 Nova works good too. There are others that work also, but these are easy to find, and don't cost to much.
