Old 01-23-2003, 07:20 PM   #1
Figment412
Several Questions
How can I lock my hood and have a release from inside the cab. It stinks that anyone can just open it and that will be bad when I get my audio stuff and such installed.
Second Question is that I want to insall kick panels and put a componet set in there. Does anyone have pictures of this done? I need some ideas on how to make it so that I can still use my high beam switch.
Are there any other modifications that I should consider for my 68/72?
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 01-24-2003, 01:56 AM   #2
casey
casey's Avatar
I've considered using a hood release off a newer vehicle. I think if you take a few measurements to get the right one it would work, that would be a good idea, and as for the speakers, I think they might be hard mounting them on the kick panel, maybe try under the dash, under the seat, doors, just a sugestion.
casey is offline   Reply With Quote
Old 01-24-2003, 02:07 AM   #3
barn9
Half a bubble off!
barn9's Avatar
You can use a hood latch off of a newer vehicle and modify it to fit, or you can get a universal hood latch kit (good ol' J. C. Whitney). Kick panels made to mount speakers are available from several vendors. There is a list of vendors on the home page of this site, and you can also use the search function for more options.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 01-24-2003, 03:12 AM   #4
Myride
Good idea.
Myride is offline   Reply With Quote
Old 01-24-2003, 05:54 AM   #5
Lippyp
English Chevy Owner
Lippyp's Avatar
I am building some boxes from MDF to mount some JBL 4" speakers on my kick panels, for components I think your only way would be to get something custom made. Most good car audio installers can build such a set-up out of MDF/fibreglass, but be prepared to pay some $$.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 01-24-2003, 09:50 AM   #6
greasemonkey
greasemonkey's Avatar
I have just done the kick panel speaker route myself. I used 6 1/2" Pioneers that I put in the pre-formed panels from Classic Heartbeat. They fit well- I had to move the parking brake over about 3/4" and it works. If you go the kick panel speaker route, don't put them on, then attempt to shove the carpet into place. I tried this the first time, and didn't like it. It tends to bunch up and gets in the way. I cut a strip of sound deadener (I have the real heavy stuff) away and it formed a depression along the edge, and the kick panel covers fit down in that. I can still hit the dimmer if I am wearing my tennis shoes but not with boots on (I wear a 13). Good luck!
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 01-24-2003, 02:07 PM   #7
Figment412
Thanks for all of the replies. I plan on making my own custom kicks out of fiberglass, plus the rear enclosure and the under dash piece that will house the H/U, switches and guages. I will have to just play aroud with and see what works best. I will consider mounting them under the dash or maybe just to corner under there. I don't have to work about the parking break at all since I will be using the hand stlye instead of the foot style.
You would think that someone would make hood latch kits for eairler model trucks. I will take a look at the universal kit from JC.
THANKS!!!
1968 GMC short bed
1972 Cab
Old 01-29-2003, 10:33 PM   #8
Blue Beard
Blue Beard's Avatar
Inside Hood Release
I agree, I've come home to find the hood unlatched.
Just picked up some trial and error pieces today at the local yard.
Have a good idea how to make them work.
Tore them done to do sandblasting tomorrow.
If they pan out I'll post.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
