3/4ton with 1 ton axels
Over the years I have seen many trucks advertised this way. What exactly does this mean?
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
Used to have a truck
It doesnt really apply to our trucks but post 73 trucks and especially post 82's often had 3/4 ton running gear with 6 lug lighter duty axles. The GVW actually reflecting what a 3/4 ton payload would be unlike our where a 3/4 ton rating truck would haul more like 3000 lbs. . A heavy 3/4 ton would be a 3/4 ton with 1 ton running gear ie 8 lug axle and suspension.
No truck :-( |
"Ochre Ogre"
I have also heard a lot of people describe the corp/eaton rearend as the "1 ton axle".
Just like the people who might call their 67-70 C-10's a "heavy half" because it came with 6 lugs.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
its all about the +6 inches
What Da-burb said is what I usually see.
Web Wheeler
6-lug 3/4-tons didn't show up until '88.
"One ton axles" on a 4x4 usually means a 14-bolt full-floater (or the big Eaton) and a Dana 60 front.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
and dana 60 front was only available under the K30's. all other series under that got the dana 44 or the 10 bolt 8.5" Corp axle so...
I've always understood the "heavy half" as a 1/2T PU with a 3/4T Rear axle setup. My memory says that with a heavy half, the front would sit lower than the rear (at least after 20 years anyways!).
-Roger
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
Cantankerous Geezer
Roger's right, but with a six lug setup on the 3/4 ton axle. If you go to the older trucks, the 3/4 and 1 ton used the same rear axle. When I was looking at 14 bolt floaters for my 52, I was told the housings were the same design, differences were in housing and axle length, drums and brakes being bigger for the 1 ton.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#9 | |
Web Wheeler
Often when ads say "1-ton axles" on a 1/2 or 3/4-ton, they mean the 1-ton axles have been swapped in. If it was "1-ton rear axle" it probably means it has a full-floating rear (original or swapped). Most 3/4-tons after '80 had semi-floating rears.
My 1967 C20 has an 8 lug / 14 bolt rear , with each out side hub having 8 cap bolts and a removeable cover to allow the axles to pull out . I understood this was a one ton full floater and It appears to be original to the truck . Did any one ton FF come on 67 C20'S ?
GM didnt even start making 14 bolt rear ends until 73. Yours was swapped in later.
No truck :-( |
#12 | |
#13 |
This might be a dumb question but are you sure its not a Dana 60 because those did come on coil sprung C20's .
No truck :-( |
#14 |
What is a 14 bolt FF worth ?
#15 | |
It's not a dumb question , Actualy I do not know how to identify a dana 60 . It is 14 bolt with the end hubs that unbolt for axle removal . |
#16 |
Oh . How many bolts does the cover have ?
No truck :-( |
#17 |
Ok my stupid , I just went and counted them again and the cover has 10 bolts and each end hub has 8 cap bolts to hold on the hub covers .
#18 |
does it look like this?
No truck :-( |
#19 |
You have a Dana 60. Welcome to the club.
No truck :-( |
#20 | |
#21 |
Do you have coils in back. I assume you do as you said you had a panhard bar. Yours is pretty rare then. Mine has coils too but I have only seen a few that do although there are some on this board who swear that none of them did. Theyr'e quite wrong . Do you know what the gearing in yours is?
No truck :-( |
#22 |
Location: Bondurant, IA but in Worcester, MA for school
Heres a better pic of a Dana 60
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
#23 |
One more...
HotRod
#24 |
Thanks for the pic's hotrod but that is not it ,
![]() MikeP , yes it is a coil rear . Last edited by Bowed; 01-28-2003 at 01:36 AM. |
#25 |
Do you have a series or studs with nuts around the perimeter on the side of the rear end that faces towards the transmission. It sounds like you have an Eaton if so .
HA HA HA ... I have the only coil sprung Dana 60 here then.... Muhaha !
No truck :-( |
