01-08-2010, 12:04 AM | #1 |
Will my axles be tough enough?
I bought a 72 gmc 1/2 ton chassis a while ago. I plan to use it under my 69 chevy. I never even thought about it when I bought it but now I was thinking I would rather have a 3/4 setup. Are the frames the same? Also how much will the axles hold up to as far as power and tire size?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
01-08-2010, 01:16 AM | #2 |
Re: Will my axles be tough enough?
If you are only doing mild offroad most people would agree that 35's are about the biggest you would want to go before having to much force on the axles.... Not sure if force is the right word though but I think you get the point.
01-08-2010, 10:51 AM | #3 |
Ya the bigger question is what will the truck be used for? Daly driving, mud, rocks, all, etc...
From 1/2ton the real upgrade is to 1ton if you plan on wheelin with bigger tires than 35" and/or installing a hot engine
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
01-08-2010, 10:56 AM | #4 |
It would be more of a mud/snow truck. Not really much rock climbing around here. As far as a drive train plans are for a duramax allison combo someday when I can afford it all, but for now I think a mild 350 is what I will install. I will probably just run the 1/2 ton axles until I have the money to upgrade.
01-08-2010, 11:03 AM | #5 |
"something witty here"
That what I was gonna do as well. I figure I will worry about upgrades when stuff starts breaking lol
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
01-08-2010, 11:35 AM | #6 |
Is a 1/2 ton dana 44 the same as a dana 44 in a 3/4 ton except for the bolt pattern? Or did the 3/4 tons come with a different front axle?
01-08-2010, 11:37 AM | #7 |
SWB 4x4 Collector
The Dana 44 is the same for 1/2 and 3/4, except the required hub changes for the lug differences. They will hold up well, but once you start putting some serious muscle to ground, it will be expected to go 1 ton, or bigger. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 01-08-2010 at 11:39 AM. |
