Old 01-17-2010, 07:07 PM   #1
67 c10 guy
67 c10 guy's Avatar
steering knuckle?
Has anyone used a newer style steering knuckle from a 01-05 with a hub
instead of a spindal? Would it even be possible to do?
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 01-18-2010, 08:36 PM   #2
DKN
Active Member
Re: steering knuckle?
Yes, I did this years ago for a SEMA Show truck. At that time we did not have our new modular spindle and brake kits.
The spindle tapers are a different size. The kingpin inclination is different. It will lower the truck by 3”. You will need to use a new OE hub. Buy it new; GM went thru many revisions in the first couple of years and had lots of bearing failures that confused the ABS sensor, and that caused brake shimmy. You will have to use a 6-lug wheel. It is a lot of work. Just use the new CPP spindles, hubs, and brakes, it’s way faster and easier.
Danny Nix
CPP
DKN is offline   Reply With Quote
hub, spindal, steering, steering knuckle
