Old 01-17-2010, 08:02 PM   #1
Big-Blue
Big-Blue's Avatar
What are you replacing your leaf spring bumpers with on lifted trucks?
Anyone found some nice looking bump stops/leaf spring bumpers for a 4" lift?
Colored, holes, cool design?
My truck is a 71 K20 but I don't think the year or model really matters..
Big-Blue is offline   Reply With Quote
Old 01-17-2010, 08:51 PM   #2
b454rat
Re: What are you replacing your leaf spring bumpers with on lifted trucks?
Bump stops??? What are they??? I never use them.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 01-17-2010, 09:12 PM   #3
Big-Blue
Big-Blue's Avatar
The rubber triangles over the axles that keep the leafs from bottoming out.
I have seen some cool ones on trucks in magazines but not sure where they came from.
Old 01-17-2010, 09:23 PM   #4
b454rat
I was being sarcastic. I never used them, but I think Energy has some.
Old 01-17-2010, 09:39 PM   #5
Big-Blue
Big-Blue's Avatar
Bingo...
These are the exact ones I was looking for....except they are $50!!
Two pieces of rubber with bolts in them...$50...
Thanks though!
Old 01-18-2010, 03:45 AM   #6
bikes&bowties
bikes&bowties's Avatar
if you are worried about hauling enough to bottom out a 4 inch lift. I dont think A lift is for you... But for ideas you could always just fab up your own. would be cheap and get the job done.?
bikes&bowties is offline   Reply With Quote
Old 01-18-2010, 09:23 AM   #7
There are ones out there for looks.I`ve never touched any of mine.Kinda forget about them,since they serve no purpose on a lifted truck.I know Rancho (red) used to make them and maybe Superlift (yellow).Not sure about blue or green.
Old 01-18-2010, 09:37 AM   #8
b454rat
I only ever used bumpstops on a truck, that was a lowered 2wd with a 4 wheeler and a bed upside down on top of the truck, that was the one and only time.
Old 01-18-2010, 11:28 PM   #9
Big-Blue
Big-Blue's Avatar
I am going for a look...not really function. (not sure what that look is)
Blue would be nice... I need to check some of the other lift companies.
Thanks for the input guys.
Old 01-19-2010, 03:17 AM   #10
ghettoluxury
ghettoluxury's Avatar
I agree
That bracket is unnecessary they are extra weight and it looks much cleaner once they are removed. imho
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-19-2010, 08:09 AM   #11
Just because I have no use for them doesn`t mean someone else shouldn`t upgrade them.That`s how I`m built.I like form and function in balance,some are all about looks,and some only function.They must make them for somebody.They really don`t weigh much.Extra weight directly over the axles is a great traction aide.
Old 01-20-2010, 09:05 AM   #12
ghettoluxury
I play tug-a-war with my truck and weight is a big thing. When you are trying to make a truck weigh 5000 lb's with 1 ton running gear every ounce counts.
Old 01-20-2010, 12:05 PM   #13
I don`t play tug of war.
You could always hold off on the french fries and potato chips.
Old 01-21-2010, 12:11 AM   #14
Maybe Fabtec or 4 Wheel Parts Wholesaler/ProComp makes blue.
Old 01-22-2010, 02:16 AM   #15
bikes&bowties
I was just on rocky mountain suspension and thought of this thread.....
http://www.rockymountainsusp.com/bumpstops.htm
