Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-20-2010, 10:30 PM   #1
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Talking desktop dyno please!!!
will someone do a desktop dyno for a combo that im going to do
350
3.48 stroke
4.06 bore
5cc flat tops
5.7 rods
stock gapped rings
im guessing .02 below deck on the piston
.04 gasket thickness and 4.1 bore
487 heads bowl blended with 1.94 1.50 valves 75cc chamber heads
i think these are the same castings as double humps
crane energizer cam 480 lift 284 adv duration
performer rpm intake gasket matched to heads
650 mighty demon
70mm turbo .80 ar 10 psi boost
thanks
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 01-20-2010, 11:18 PM   #2
ripdog28
ripdog28's Avatar
Re: desktop dyno please!!!
Desk Top Dyno is crap. Usually way off. Contact Super73 or look at the link in my sig. Super has an excellent program that has proven to be within a few ponies. If i were to guess on it, 275-300.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-20-2010, 11:24 PM   #3
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i changed it some
Gage
Old 01-20-2010, 11:28 PM   #4
ripdog28
ripdog28's Avatar
Oh, didnt see the turbo. I would still try to get some 2.02 heads.
69 c-10 BBC
Old 01-20-2010, 11:35 PM   #5
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
will they cut to that big
Gage
Old 01-21-2010, 01:04 AM   #6
ripdog28
ripdog28's Avatar
Yea almost all 350 heads will and im sure those will. You will probly be better off getting a $500 set of vortech heads then spending the money on those old heads.
69 c-10 BBC
Old 01-21-2010, 02:11 AM   #7
mongoose
mongoose's Avatar
kinda hard to run boost when you're already at like 10.51:1 on iron heads =/
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-21-2010, 05:42 PM   #8
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
they have 75cc chambers shouldnt that bring me down to about 9 to 1
Gage
Old 01-21-2010, 07:41 PM   #9
Super73
Super73's Avatar
I started building a engine profile for you, but, garbage in = garbage out.. Please take a look at this thread. I need all the info listed or it won't be near right..
http://67-72chevytrucks.com/vboard/s...d.php?t=317628
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-21-2010, 08:20 PM   #10
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Engine info
Bore -
4.060
Stroke - 3.480
Factory tolerances or set up more as a race motor? - factory tolerances
Electric Water pump? - no
Electric Fan? - yes
Head data:
*----* Intake and Exhaust Valve size -
1.94 1.50
*----* Head flow numbers (Please provide them or a link to MFG's website, I don't want to have to search for info. If these are stock heads, try to give me a casting or something) - 487 heads
Compression ratio - 9 to 1
Type of intake (Single plain, dual plane, again link if you can find it). - edelbrock performer rpm dual plane http://www.edelbrock.com/automotive_...lds_main.shtml
Carb or TB (Is it a vacum carb?) - 650 mighty demon blow through http://www.barrygrant.com/demon/default.aspx?page=14
Header Data:
*----* Tube Diameter -
1 3/4
*----* Tube length to collector (this can be your best guess, but the more accurate, the better) - 30 in
cam info:
Link to MFG's web page or cam card would be best but..
Duration at .050"
Total Lift and based on what rocker ratio
Intake centerline
LSA -
i cant find anything on the cam so ill go with a diff one
heres a lunati voodoo
Advertised Duration (Int/Exh): 284/292
Duration @ .050 (Int/Exh): 241/249
Gross Valve Lift (Int/Exh): .525/.546
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2500-6600
What rocker are you using? -1.5 harland sharp
Blower/turbo? - 70mm .80 ar 10 psi
I need to know size and PSI you are running.
Intercooler? Air to Air or Air to water? -
no intercooler
Vehicle Data (I am going to try to keep this simple and use my aero for the most part). - 1964 c10 short fleet
Total weight - guessing 3800
Front/Rear weight bias - ?
What trans you are running (Gear ratio if different than stock) - th 350 stock
Size converter (STR if you have it) - 2700 b & m 12 inch
Gear ratio - 3.73
Differential (Open, production posi, spool) - gov lock
Tire size (height, width and type, again if you have a link to the MFG's page, even better). - 275 60r15 mickey thompson et street radial http://www.mickeythompsontires.com/s...ETStreetRadial
Gage
Old 01-21-2010, 08:47 PM   #11
Super73
Super73's Avatar
I'll see what i can come up with, but you sure your headers are going to be 30" length? Where are you mounting the turbo?
487 heads? Sorry, not a big old school guy. Do you know any factory flow data? Are they similar to a 462 casting? 441? 882? These are heads that are preloaded. If not, I'll need flow numbers for .300 .500 and .600
Old 01-21-2010, 08:53 PM   #12
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
umm i forgot about them being turbo headers i guess around 18
-at .100"-.200"-.300"-.400"-.500"-.600" valve lift
-int-52-103-155-177-185-193
-exh-44-81-111-128-128-128
plus a little bowl work and a little combustion chamber smoothing
Gage
Old 01-23-2010, 12:08 AM   #13
Super73
Super73's Avatar
I'll be gone for a couple weeks and will finish up when i get back.. sorry for the delay...
