Spark plugs and carb?
Im almost finish putting together my 427bb and i have two questions.the first one,wat kind of spark plugs should i use?any part numbers.the engine is a 427 bored 30 over, 049 oval ports with 2.190/1.88 valves.trw dome top pistons @10 to 10.5 compresion,comp cams 292 magnum cam.the second one, im thinkin of goin with a proform 850 carb.summit part#67201 do yal think this is a good carb to go with?is it good size, too small or too big?
![]() Join Date: Jul 2009
Re: Spark plugs and carb?
damn bro nice set up. Did you build it.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
HOARDING SPECIALIST
![]() Join Date: Sep 2009
I would go with a holley street hp 950 it should work very good. I think the ngk race plugs work very good for $2.99 each. I have seen nothing but bad luck with the pro form carbs last one i seen had the boosters in crooked. Just my opinion stay away from the pro form carb. Good plug to start with if you use the ngk is 5673-7
BAD BOW-Silverado XST
I use NGKs on a 10:1 compression ratio ZZ4. They work great!!
Yeah Craig has done some heads for me on my 08 silvy. if i dont buy a crate engine i will probably get him to rebuild my current one.
Thanks a lot guys for the responses.anybody else have any opinions on the proform carbs?anybody running delco rapidfires?
I've heard a lot of bad things about the Pro Form carbs. Stick with a name brand, you get what you pay for.
buy a holley hp750. I don't like the quick fuels either. I might be able to get you a deal on one if you decide to go that way.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
I've read a few threads lately about pro-form and it sounds like their quality control is in the pooper. What about getting a custom carb?...like Braswell or ProSystems. I hear they can tune the fuel curve for your combo. That's what I wanted to go with, but for now I chose to keep messing with my current 750DP so I could learn a little bit on my own.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
#13 |
Well after hearing all this stuff about proform i think im going with a holley 4150 hp carb.still unecided on the plugs though.
