Old 01-25-2010, 01:09 PM   #1
Scrub
Collector of rusty Items
Scrub's Avatar
Question about 1990 blazer brakes
I have a 90 k5 blazer that I am putting dana 60 and corp14 axles under. I have a doner truck that has hydro-boost brake that I an grafting into the K5.
My question is this. What to do with the wires that come out of the factory proportioning valve? I assume there are two switches and that if if short the 2 pairs of wires to each other that everything will work. Or, can I just unplug the connector and be fine?
Thanks in advance
TW Scannell
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 01-25-2010, 09:55 PM   #2
Re: Question about 1990 blazer brakes
I moved this from the parts board.I think someone has experience with hydroboost here.
