Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-25-2010, 07:43 PM   #1
ont_guy_38
ont_guy_38's Avatar
Carb Choice
Bought an engine for my truck and am slowly putting the pieces back on as the my buddy is building a new engine and wanted to keep some stuff and one of them is the demon carb that was on it which worked awesome in his nova . The motor is a 350 standard bore,flat tops,air gap intake with porting work and vortec heads with a fair amount of porting done to them.The cam is a Comp , duration 228 int ,234 ext, lift int 480 ext 499 with 4/7 swap and 1.5 ,1.6 rocker combo,Turbo 400 tranny with 3500 stall converter (maybe overkill but going to try it) . Eventually 4 something gears in rear end.i dont drivr the truck much and plan on playing at the track a bit so i,m wondering 650,750,mechanical or vaccum secondaries,it will be a holley...thx to all that reply
ont_guy_38 is offline   Reply With Quote
Old 01-26-2010, 11:38 AM   #2
toms84ss
Re: Carb Choice
I'm a Holley fan. Depending on the rear gear, I think I would run a 650 DP. You could probably get the 750 to work but I think the 650 would be a bit crisper in the throttle response. I've had good luck with the Street HP series carbs.
toms84ss is offline   Reply With Quote
Old 01-26-2010, 01:06 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Carb Choice
I agree,, 650,but being primarily a street vehicle I'd use a vacuum secondary carb. That's a pretty mild cam and wouldn't support the rpm it would take for a 350 to want a 750. IMO let him keep the Demon,, your WAY better off!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-26-2010, 11:58 PM   #4
djracer
djracer's Avatar
Re: Carb Choice
I had a similar motor in my old street truck and I had a 650dp on it and I loved it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
