Old 01-29-2010, 09:47 AM   #1
HeavyChevy87
Show me your body lifts!
I'm looking to get a 3 inch body lift for my truck. It's on 33 12.50s.
What did you have to move or relocate? Any chance it will clear 35's later on?
HeavyChevy87 is offline   Reply With Quote
Old 01-29-2010, 09:50 AM   #2
HeavyChevy87
Re: Show me your body lifts!
Can someone move this to 4x4 tech? Thanks!
Old 01-29-2010, 10:07 AM   #3
ToughBowtieTruck
Front bumper needs relocating to look right. I don't think there is a kit for 73-80 frames though . . . might want to check.
Fan shroud needs some sort of modifying as well as the fuel filler neck.
If you have a manual transmission, you need to lengthen the clutch rod if it is a mechanical linkage. Same with 4 wheel drive if it isn't a 205 transfer case.
Master cylinder brake lines need to be checked to see if they can stretch too. Look over the wiring harness and make sure nothing is being stretched.
Also anything from frame mounting to the body like ground wires, axle vent tubes, etc need to be taken care of.
That's pretty much it.
-Josh
"Mr. Simpson, there are thousands of people like you with no discernible talent." Duff World Records Division
"Yeah, they're called Congress!!" -Homer Simpson
ToughBowtieTruck is offline   Reply With Quote
Old 01-29-2010, 10:38 PM   #4
67chevy77
67chevy77's Avatar
when i bought my truck(77 k10) all it had was a 3 inch body and it cleared 35s (on 10 in wide rims) but if i remember right i had to bind the little lip on the front finder because it rubbed a little.
Justin
1977 chevrolet rebuilt 350 9 inches of lift with 40s 4.56 gears. Work in progress.
1967 4x4 -sold-
1988 reg cab short bed 4x4 -sold-
1999 GMC extended cab short bed new body style Lifted on 33s.
67chevy77 is offline   Reply With Quote
Old 01-29-2010, 11:03 PM   #5
My 35s mounted on 10" wheels rub some with a 4" lift on my`91 Suburban.
