Towing a 4x4 on a tow dolly.
I might be towing a blazer on a tow dolly. It is a 4 speed, so if it was a 2 wheel drive I would not have to disconnect the drive shaft, but since it is a 4 wheel drive, what do I need to do?
If I put the transfer case in the 2wd position, will it disconnect the front driveshaft? |
neutral
Place the transfer case in neutral or remove the driveshaft from the axle that is still in contact with the ground. Either way. Third option is put the rear axle on the dolly, placing the front axle on the pavement and unlock the hubs (if so equiped).
1967 K30 Napco 292/SM420 original paint 30k miles 1968 K60 Napco 396/5spd. dbl frame 52" michelins 1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks 1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr 1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison. |
It the transfer case is in neutral, I should be able to leave the rear drive shaft connected, since it is a 4 speed and will self lubricate as the back wheels turn? Thanks
![]() Join Date: Aug 2001
![]() ![]() ![]() ![]() (PS EVERYONE NEEDS A TOWTRUCK OF THIER OWN ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 01-29-2003 at 04:11 PM. |
its all about the +6 inches
Where you finding a dolly that is wide enough?
I've never seen one. |
#6 | |
Model KK360SB Plus, take a look at this link ![]() http://67-72chevytrucks.com/vboard/s...threadid=38089 |
Interesting, I never read that thread.
The only dollys I ever seen wide enough were home made. Cool. |
