Grease Monkey
Help adding a trans temp gauge
I have been going back and forth on whether or not to go with Autometer gauges or buy the white faced stock gauges. Here is my first question. Can I add another stock temp gauge in place of say my vacuum gauge and have it read the trans instead of the engine temp? Next question is where should I install the sending unit? The three ideas that I have come up with are 1. install the sending unit instead of the drain plug on the pan, 2. weld a bong on the pan, or 3. install a tee at the cooler. Thank in advance for the input.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Re: Help adding a trans temp gauge
I had a motorhome with a 4L80e in it and I installed the trans temp in the drain plug, worked well. That was quick and EZ. Next time you pull the pan have a bung welded in and get the drain plug back. In the vaccume hole would be nice.
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid ![]() |
Sofa King. We, Todd, Ed.
B&M makes a trans pan drain plug kit that happens to be the same size hole/thread as most transmission temp gauge electric sending units.
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
I've seen kits to tee them off the cooler line too. I made my own with stuff from the plumbing store. I plumb it into the line that goes TO the cooler to monitor temp before cooling. Whereever you put it make sure there is enough depth that it is in fluid and not bottomed out on metal.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 02-09-2010 at 08:29 PM. |
