02-02-2010, 10:23 PM | #1 |
Upper ball joint installation
I am installing new Moog ball joints and have a question. It shows in the directions that the bolt head is down and the threaded portion is up. I have seen it the opposite way on other trucks. Does it matter which way they go in? Here is the drawing;
02-02-2010, 10:29 PM | #2 |
DON'T TREAD ON ME
Re: Upper ball joint installation
I don't think it makes a lick of difference. If you're concerned about it, you can't go wrong by following the manufacturer's instruction.
Old Yeller |
02-03-2010, 01:17 AM | #3 |
it is wise to always put bolts on the top and nuts on the bottom on most any assembly, if the nut comes off then the bolt is at least still retained. but as stated everyone is correct I overlooked that we were talking bout the ball joint and boot, bolt up and nuts on top of arm to protect boot from rubbing.
what i get for being tired while posting...LOL
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? Last edited by Rooster's 67; 02-04-2010 at 01:53 AM. |
02-03-2010, 02:51 AM | #4 |
I have always read the bolts go from the bottom to top in all the gm manuals. Main reason is with this is the excess threads coming out of the nut wont rub the grease boot.
02-03-2010, 08:04 AM | #5 |
you put the threads going down then when you try putting the spindle on you find out why the picture shows you shoulda put them pointing up
02-03-2010, 12:33 PM | #6 |
Never Ending Projects
70stroker and cdowns got it correct. Both are the reasons to put the bolts from the bottom side up.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-03-2010, 04:27 PM | #7 |
I have seen this in the shop before. The nuts go on the top and on some trucks if mounted the other way when the suspension is lifted the stud of the bolt will hit the steering knuckle and will not be able to steer the wheels which could also be a safety issue in some driving applications.
02-03-2010, 05:33 PM | #8 |
I am a Referee of life.
^ they're right ^
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-03-2010, 05:35 PM | #9 | |
Gravity sucks sometimes
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
02-03-2010, 06:15 PM | #10 |
When all else fails...follow the directions....
02-03-2010, 06:40 PM | #11 |
Just as the concensus is, the bolts face up with the nut being on top. Reason being it can rub on the dust boot eventually tearing it, which will allow contaminants in and cause premature failure. Another reason as stated it can effect the turnability. Also through the travel of suspension the dust boot flexes in many directions and with vibration the nuts can become loose. Having replaced hundreds of these and just working on gm vehicles in general I highly recommend the use of locktite apon installation.
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
02-03-2010, 08:46 PM | #12 |
nuts up!
02-03-2010, 10:58 PM | #13 |
I went with what the instructions said and used Locktite Red. I always have my "Nuts UP" when I can. As a side note here is a drawing of the ball joints. I never knew that the upper ball joint were non load bearing.
Vancouver Bob |
02-03-2010, 11:06 PM | #14 |
On suspension with the spring below the upper control arm, the bottom ball joint it the load bearing one. If the spring is above the upper control arm the upper ball joint is the load bearing one.
02-03-2010, 11:08 PM | #15 |
True
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker |
02-04-2010, 01:37 AM | #16 |
I really hate wet sanding!
put in half from the bottom up and half in from the top down...at least you will be half right!
it makes no difference
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
02-04-2010, 02:42 AM | #17 |
Nuts up....just like the pic If all else fails pull the instructions out of the trash can! Now I know that the instructions are just some other azz ho;s idea about how to do things,but if all else fails FOLLOW that azz ho,s instructions The ones on my Longhorn are bolted in as per pic, & they aint fell out in 12000 miles. crazyL
http://community.webshots.com/user/hotrodhorn |
02-04-2010, 02:24 PM | #18 |
Dud your avatar is freaking me out. Could you pretty please change it? Something about pixellated clowns makes me skirmish...
1968 LWB C20 / AC / Wood Bed |
