Location: Bondurant, IA but in Worcester, MA for school
Short or Long Water Pump???
Is this a short or long water pump? Thanks
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
short
69 chevy short wide box project 70 GMC jimmy project |
How can you tell if you dont mind me asking? Thanks
HotRod
Recovering 67-72 Addict
![]() Join Date: Oct 2000
Yep, it's a short. How can you tell? Because it is not long! Seriously, once you've seen them both it is very obvious.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
The easy way to tell is you should be able to slide your hand between the water pump and timing chain cover. You will not be able to on a short as seen in the pic.
Fabricate till you "puke"
I have a side shot of a long pump on my 69. You will notice the alt is mounted on the pass side..... http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
