01-29-2003, 11:26 PM | #1 |
Project 7dos
How Do You.....?????
how do you check the distributor end play, between the distributor shaft and the oil pump shaft??? we want to know how much shim we need between the distributor and intake....
How do we determine this Thanks Jason
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
01-29-2003, 11:35 PM | #2 |
Set the distributor in the motor with no gasket. Use a feeler gauge to calculate how much space is available between the two. Meausure the gasket and figure a compressed height. Do some math. Should let you know if clearance is OK or needs to be shimmed.
