Old 02-05-2010, 11:31 AM   #1
lovnthe70
lovnthe70's Avatar
New Carb Running hot at idle
so i put on a rebuilt carb its a qjet and i dialed it in to what seems to run pretty good, but ever since i put on this new carb my engine temp rises at idle when at stoplights and what not from about 190 to 200, and my temp switch is in the block just above the manifold so i think the temps read about 10 higher than they actually are, at least according to a digital temp reader. Is this normal? i am worried cause i live in phoenix where it gets hot as hell and if it is doing this in the winter i don’t want to see what happens when i am sitting at a stoplight and its 105 degrees out! does it sound like i am running to rich or lean on my fuel mixture or idle? Has also been sputtering and running for a few seconds after i turn it off....like its angry i am not going to drive it more! my idling oil pressure seems to fluctuate, sometimes its 30 sometimes its 40 then when i drive its up around 60-70. thanks for the help it is a newly rebuilt engine with about 700 miles on it.
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 02-05-2010, 01:16 PM   #2
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Re: New Carb Running hot at idle
Good Morning,
Usually speaking an engine that continues to run after the ignition is turned off indicates ignition is too far advanced. Check your timing. Advanced to far can also affect engine temps. Bad gas and low octane can also contribute to this. God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 02-05-2010, 01:18 PM   #3
lovnthe70
lovnthe70's Avatar
alright thanks ill look into that, didnt even consider it because i just set the timing about 2 weeks ago. So should i run 89 octane? i have been using 87.
1970 GMC- 454
Old 02-05-2010, 01:21 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Almost guaranteed it's not the carb. too many other possibilities.
prostreetC-10 is offline   Reply With Quote
Old 02-05-2010, 01:22 PM   #5
lovnthe70
lovnthe70's Avatar
i just figured the carb because that same day i didnt have any of these issues untill i swaped on the carb.
1970 GMC- 454
Old 02-05-2010, 06:44 PM   #6
coloradosean2009
coloradosean2009's Avatar
You have a vac leak. Check the carb gasket with a can of spray cleaner while the engine is running. If the idle changes, you have a leak.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 02-05-2010, 06:54 PM   #7
lovnthe70
lovnthe70's Avatar
alright ill do that when i get home, i adjusted my idle at lunch and it stoped gurgeling and shaking after i shut it down so as far as i can tell i got that fixed for now. thanks.
1970 GMC- 454
idle, oil pressure, qjet, temperature
