02-21-2010, 10:43 PM | #1 |
Signals in the bumper.
Oil pressure sending unit, '81 305
The only sending unit I can find is the one in the photo above the oil filter with two connections; however, the wiring diagram shows a single connector. Is this my sending unit above the oil filter? If so, what is the other connector for?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
02-22-2010, 10:59 AM | #2 |
Re: Oil pressure sending unit, '81 305
The sender you have pictured is the Choke switch. The oil pressure switch for the gauge should be behind the distributor and will have a single blue wire.
02-22-2010, 06:29 PM | #3 |
FYI, this was helpful.
02-23-2010, 10:36 PM | #4 |
Found my problem. Apparently I am missing the majority of my sending unit, haha.
