Old 02-23-2010, 10:41 PM   #1
ah_5500
Rear end help needed
I have a 67 burb and a 67 shortbed both v8. I might be trading the burb off so I want to take the spool out of it since it's posi and swap it with the ring in my shortbed. Will this work? Same case? Would i have to change the pinion? Thanks fellas.
ah_5500 is offline   Reply With Quote
Old 02-23-2010, 11:33 PM   #2
drbyrdman
drbyrdman's Avatar
Re: Rear end help needed
are they 1/2 ton or 3/4 ton????
drbyrdman is offline   Reply With Quote
Old 02-23-2010, 11:49 PM   #3
ah_5500
1/2 ton. 6 lug ofcourse
Old 02-24-2010, 01:08 PM   #4
rics34
check and make sure some gears use a bigger size spool and are not interchangeable with spools using a different gear. Change the pinion and no problems with a complete swap or it may be easier just to swap out entire rear. It is a good time to go thru and refresh the one you want to save.
keep on truckin
Rick
rics34 is offline   Reply With Quote
Old 02-24-2010, 08:43 PM   #5
ah_5500
well ive been debating and i think im going to keep my burb...cant let a 327 with posi go, and i already have a restored 67 shortbed, now i need a blazer, lol... but if i do ill swap the entire chunk like you mentioned.
