Old 02-24-2010, 09:34 PM   #1
MONTE
MONTE's Avatar
Project "Ghost"
Let me tell you a little about this project. It all started a few years ago. I paid $500.00 for this truck up in north Texas. Truck is in good condition. Needs body work on the normal areas, but nothing major. So I did some modifications on it. It's a 1968 Short bed truck, or so I thought. I crawled under the other day and found out it was a long bed. Work don't look to bad. I was kind of upset cause I thought it was an original. Well Project "Ghost" was given its name from my wife. She says that I just put money into this truck, but she never see's any progress. Well i'm hoping on finishing it by October. We will see.Name:  image6.jpg
MONTE is offline   Reply With Quote
Old 02-24-2010, 09:40 PM   #2
MONTE
MONTE's Avatar
Re: Project "Ghost"
Random pics after i got it to my barn.
With A/C.
Old 02-24-2010, 09:45 PM   #3
MONTE
MONTE's Avatar
Re: Project "Ghost"
Dads 49 plymouth. Sitting for 30 yrs.
Old 02-24-2010, 09:58 PM   #4
MONTE
MONTE's Avatar
Re: Project "Ghost"
Cleaning the engine bay.
Not bad for first time painting with spray gun.
Some "Ghost" goodies.
More painting.
Old 02-24-2010, 10:09 PM   #5
MONTE
MONTE's Avatar
Re: Project "Ghost"
Old 02-24-2010, 10:13 PM   #6
MONTE
MONTE's Avatar
Re: Project "Ghost"
454 with many goodies!!!
Old 02-24-2010, 10:18 PM   #7
MONTE
MONTE's Avatar
Re: Project "Ghost"
More parts.
Assembling it again.
Fuel system.
Old 02-24-2010, 10:24 PM   #8
MONTE
MONTE's Avatar
Re: Project "Ghost"
Header problems, so I had to modify.
Old 02-24-2010, 10:44 PM   #9
MONTE
MONTE's Avatar
Re: Project "Ghost"
I did some measuring for the rear wheels.
I have 5 1/2 inches from the inside of the fender to the drum.
12 3/4 inches from the inside fender to the wheel tub.
7 1/2 inches from the outside fender to the drum.
14 1/2 inches from the outside fender to the wheel tub.
would a 12 wheel fit in the rear or do I need to tub it?
Old 02-24-2010, 10:47 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Re: Project "Ghost"
Following along...very nice looking engine.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-24-2010, 10:49 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
Re: Project "Ghost"
I've always read a 10" is the widest wheel you can run with stock tubs. Even though there is more space than that you need clearance and also depends on the width of the tire going on the rim.
Old 02-24-2010, 10:52 PM   #12
MONTE
MONTE's Avatar
Re: Project "Ghost"
thanks for the response, i've seen a couple of projects on tubs so i might just give it a shot. I want something that will stick, I think i can add a few inches on each side.
Old 02-24-2010, 10:54 PM   #13
MONTE
MONTE's Avatar
Re: Project "Ghost"
These are some pictures I got from one of the members here. I like the width on the tires.
Old 02-24-2010, 11:41 PM   #14
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Re: Project "Ghost"
Lookin Bad Ass!
Same fuel system I used
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 02-25-2010, 09:16 AM   #15
MONTE
MONTE's Avatar
Re: Project "Ghost"
Hopefully I will have it started by this weekend. I need to see about my header problem.
Old 02-28-2010, 07:55 AM   #16
MONTE
MONTE's Avatar
Re: Project "Ghost"
Found some wheels with summit.
Torq thrust 15/8 and 15/12. I wanted to go with 18's for the front and 20/12 rear, but all I found that I liked run around 1200 a wheel. I'm still thinking about what I should get.
Old 02-28-2010, 09:41 AM   #17
RCbowtie69
RCbowtie69's Avatar
Re: Project "Ghost"
Hey from N.C. looking good. keep up the hard work
RCbowtie69 is offline   Reply With Quote
Old 03-05-2010, 04:55 PM   #18
MONTE
MONTE's Avatar
Re: Project "Ghost"
looks like engine is coming back out, I don't like the issues with the headers hitting, so im just going to move the tubular engine mounts back about 1/2 inch. that should fix my problem.
what do you guys think about running a hydoboost break system?
Old 05-10-2010, 11:07 AM   #19
MONTE
MONTE's Avatar
Re: Project "Ghost"
Little update on the Ghost. I just finished ordering some auto meter gauges and some gears!!
Hoses are expensive, but look nice.
Solid motor mounts
dual fans are a must!!
Old 05-10-2010, 11:48 AM   #20
67cheby
67cheby
67cheby's Avatar
Re: Project "Ghost"
sweet MOTOR
67cheby is offline   Reply With Quote
Old 05-10-2010, 02:19 PM   #21
MONTE
MONTE's Avatar
Re: Project "Ghost"
thanks its a 454 with some options..
Old 05-14-2010, 03:46 PM   #22
MONTE
MONTE's Avatar
Re: Project "Ghost"
Autometer cluster project. I've seen some projects with replacing the guages so I decided to give it a try.
Cant forget the gears "373" with auburn locker
Old 05-14-2010, 03:47 PM   #23
MONTE
MONTE's Avatar
Re: Project "Ghost"
Custom made driveshaft should be coming in this week.
I also ordered a transmission cooler.
will be posting pics soon.
Old 06-24-2010, 08:59 PM   #24
MONTE
MONTE's Avatar
Re: Project "Ghost"
What did Brown Santa bring me?
Thanks to the wife!!
Old 06-24-2010, 09:03 PM   #25
MONTE
MONTE's Avatar
Re: Project "Ghost"
I also placed an order for a vintage air system from Scottshotrods.com.
They will give you a good deal. I will post pics once I get the order in.
