Old 03-01-2010, 10:02 AM   #1
403oldsman
Deutz 4x4(1985 GMC)
Got the motor off eBay. Its an F5l912 deutz.It has a Chevy bell housing adapter. My 6.2 gave up in my 2wd, so i got a 4x4 frame and am going to swap the body over. Going to use a 700r4 to a np241 and 3.08 gears for a cruise speed around 1500rpm.
THERE is NO REPLACEMENT FOR DISPLACEMENT
1971 CHEVY 4X4 4SPD 406 CHEVY Lockers front and back
1978 BONNEVILLE 403 OLDS
1985 K1500 F5L912 Deutz Power (work in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=389561
1963 Oliver 1600 diesel
1956 Oliver Super 88
403oldsman is offline   Reply With Quote
Old 03-01-2010, 10:04 AM   #2
403oldsman
Re: Deutz 4x4(1985 GMC)
a few more pics
Old 03-01-2010, 10:07 AM   #3
403oldsman
again
Old 03-01-2010, 10:10 AM   #4
403oldsman
Here is where I'm at other than I fabbed some engine mounts.
Old 03-01-2010, 10:53 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Tell me a little about the motor - not familiar with it. Cool project for sure.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-01-2010, 12:30 PM   #6
403oldsman
Its a German made air cool diesel. Its 288 cubic inches. 4.72 inch storke and a 3.9370 bore. It make 100 hp at 2800 rpm and about 308 ftlbs at 1450rpm. Not bad for a NA diesel. 5 individual jugs and 5 individual jugs that can be replaced independant of the other cylinders and can all be done without removing the oil pan. In other words if you score one cylinder you can buy one new jug and piston with the misc. parts and repair it in the vechicle.
Back in the 80's deutz used these 5 cylinders as an $8000 dollar swap for American trucks and vans. Motors came with a 300,000 mile warranty.
According to stories from my grandpa a guy had one in a chevy van and got 30 mpg pulling or not.
Parts a pretty cheap if you know where to find them. (ie injectors were $36.00 a piece, valve cover $7.90 a piece.
Deutz also made 2,3,4,6 versions as well. They all used the same jugs and heads.
Old 03-01-2010, 01:24 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
Wow, that's a very interesting motor.
Old 03-01-2010, 02:31 PM   #8
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Dude, thats badarse! I've always loved Duetz and have always tossed the idea of one in a C/K, thats sweet you did it! You gotta get some videos up when its done!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-01-2010, 03:46 PM   #9
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
The Duetz F diesel is a damn fine example of German engineering. Simple, reliable, and economical modular design. In for the build.
On a side note, looks like you have plenty of room for a little turbo
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 03-01-2010, 05:49 PM   #10
403oldsman
Once I get i running and driving a turbo is going on.
If anyone wants any specific pic I'll do my best to get them.
My next step is to add some leaf springs in the front to help the 13 quart oil pan clear the front differential. Its about 3/4 of any inch front sitting on top of the pumpkin.
Thanks for the perks.
Old 03-02-2010, 02:17 AM   #11
chas350
Air cooled? How reliable is that in a warm climate?
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 03-02-2010, 02:40 AM   #12
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Sweet looks like its gonna be a fun ride for sure. Keep up the good work!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-02-2010, 03:14 AM   #13
Dooley
Dooley's Avatar
I posted this Deutz-Chevy in 2008.
http://67-72chevytrucks.com/vboard/s...28#post2755128
Dooley is offline   Reply With Quote
Old 03-02-2010, 09:26 PM   #14
403oldsman
here is a website of the 79 3/4 ton with more pics
http://picasaweb.google.com/bebopdel...Cx7qPWsOH3hwE#
Make sure you check out the two videos
As for air cooled having hot issues we have 6 cylinder in a deutz 100 06 tractor that won't overheat pulling a plow busting sod or grinding feed in the middle of a 90+ degree day in the summer.
If you think about it, all the water does in a liquid cooled motor is transfer heat from the cylinders to the air. A deutz just removes the water from the equation.
Old 03-03-2010, 12:41 AM   #15
Dooley
Dooley's Avatar
Great link. Thanks!
Old 03-03-2010, 02:01 AM   #16
vk_chevy
vk_chevy's Avatar
way to go, that is very cool power plant, don't know much about that engine but it sure is cool.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 03-04-2010, 12:47 AM   #17
americanmusc1e
americanmusc1e's Avatar
x2
I drove a 65hp deutz 4cyl pulling a shredder that was too big for it and It outpulled and stayed cooler and used much less fuel than the other tractor (an older 90hp 6cyl Oliver) we used in a 100+ degree Texas summer.............one note though, when operating in dusty conditions you have to blow out the dust from around the cylinder jugs every now and then or cooling efficiency will be greatly reduced
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-04-2010, 02:49 AM   #18
84 400
Sb 400 club
84 400's Avatar
COOL never heard or new of these. Great alternative to a 6.2 or a 6bt
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-05-2010, 11:01 PM   #19
sierra4x4
sierra4x4's Avatar
Cool build. I have often thought about putting a Deutz into a truck. I think these engines are great. I work as a mechanic for a railway that is in a very remote area and all of the gen sets use Deutz engines. They have 2,3,5 and 6 cylinder engines that run 24 hours a day 7 days a week and they run for years! I cant even imagine how many hours some of those engines have on them. I can't wait to find out how it works for you.
sierra4x4 is offline   Reply With Quote
Old 03-06-2010, 12:04 PM   #20
ERASER5
ERASER5's Avatar
So how are you going to heat your truck? A/C would not be much of a problem with the proper size clutch pulley. Low rpm engines usually need small clutch pulleys to keep the compressor up to speed.
Ford was working on an electric heater to run before the coolant was hot. Maybe that would work. Or JC Whitney should have an electric heater of some sort.
I like diesels. I have a 6.9IDI International. It is OK, but I want a 7.3IDI, the bigger brother. I'll be watching and waiting.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-06-2010, 12:10 PM   #21
ERASER5
ERASER5's Avatar
Do you have a vacuum pump for the brake booster?
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-06-2010, 12:11 PM   #22
403oldsman
for heat i plan on using a oil cooler inplace of the heater core. For ac i think it will work fine because the crank pulley on the deutz is about twice the size of a regular chevy. It should spin the other pulleys faster.
For cold starting I'm going to use a cummins grid heater. I'll post new pics as soon as I change the hard drive in my other computer.
Old 03-06-2010, 12:53 PM   #23
desertrat
desertrat's Avatar
Subscribing so I can learn more....
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 03-06-2010, 01:05 PM   #24
403oldsman
for brakes I'll beusing the trucks hydraboost since a 6.2 diesel was in there before. The motor came with a vaccum pump on it that is lubed by the engine oil. I use that for the cab acessories.
Old 03-06-2010, 06:54 PM   #25
ERASER5
ERASER5's Avatar
Great. This should be very interesting. Low end torque. That is where it is at for a work truck!
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
