03-05-2010, 09:37 PM | #1 |
My '63 Front Disc Conversion
If I had to do it again, I would find a donor truck with 1 1/4” rotors and just pull the entire cross-member, booster, and anything else I might need and just replace the 5 lug with the 6 lug. I would then rebuild it, pull the engine, slide it under and be done. Guess you could brace the engine in place but I wouldn't risk it.
Or I would just buy a complete front disc kit. I think I saved about $500 not buying the kit but who knows. Once you start buying bolts and other crap it adds up quick. I was able to take the $500 I saved (or think I saved) and buy new shock/coils and a sway bar kit for the front and the rear. I haven't installed the rear shocks or coils or the sway bars. That will take place in a week or two. All my parts came off a '79 HD pickup or I bought new. I'll hang on to the 5 lug rotors from the salvage yard and use them when I upgrade the rear end. Here are the things I know, or at least think I know... The upper, lower, and outer tie rod ends are the same for the '79 HD and regular braking system. The only thing you really need is the caliper, spindle, rotor (if you're going to 5 lug). I'm not ready to buy new rims or upgrade the rear end so I purchased a pair of 6 lug rotors from CPP. The modifications I had to make, 1)Drill hole to attach the brake line to the upper control arm.. (See picture) 2)Drill hole through frame for end of brake hose. (See picture) 3)I also had to drill new holes for the power booster. (Save time and a clean install, Captain Fab offers a bracket that will bolt directly to the frame.) O'Reilly Auto Parts Lower Ball Joint – MPC K6117 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Upper Ball Joint – MPC K6136 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Tie Rod End, Outer – MPC ES409R (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Brake Hose – BH177187 &731 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Brake Caliper – A1 18-4126 &27 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Brake Pads – BB MKD52 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Wheel Bearings – BCA A3 &A5 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) Wheel Seal – NAT 8871 (for 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors) They also have a Compatibility database when looking up parts. 3/16 brake line for the front and ¼ for the back. LMC Tie Rod End, Outer – 34-2001 (Because of the threads in the adjusting sleeve, this outer tie rod end will become the inner tie rod end.) Classic Performance Parts 6-Lug Rotors – _CP4R6 Performance Online High Performance Tie Rod Adjusting Sleeves (63-70 for disc conv. Using 73-87 spindles) HPAS6370 1979 ½ Ton Heavy Duty Pickup with 1 1/4” Rotors Spindles Calipers 5 lug rotors 1985 C10 (These parts would have worked but I went with the CPP setup) Mast Cylinder Power Booster Proportioning Valve $65 for a new front end alignment. Took the guy at Hibdon over an hour to get it right and he was not happy... Oh yea, have fun getting the lower ball joint off. Took me 4-5 hours of hammering, a small bottle of propane, scissor jack, 2 broken forks, and a lot of cussing to get them off. Torque Specs Upper ball joint to a-arm - 45 ft/lbs Upper ball joint to spindle - 40 to 60 ft/lbs. maximum of 90 ft/lbs to align cotter pin hole Lower ball joint to spindle - 80 to 100 ft/lbs. maximum of 130 ft/lbs to align cotter pin hole Here's a picture of how sits now.. Got to get busy on the body work now..
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 03-05-2010 at 09:46 PM. |
03-05-2010, 09:38 PM | #2 |
Re: My '63 Front Disc Conversion
Pictures of the holes I had to make for the new booster..
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion |
03-05-2010, 09:40 PM | #3 |
The holes I had to drill in the frame. Then of the hose on the wheel site and the hard brake line on the inside.
03-05-2010, 09:43 PM | #4 |
Picture of the hose connected to the control arm and the power booster...
03-05-2010, 09:44 PM | #5 |
It doesn't stop on a dime but it's night and day to the old drums.
Hope this helps someone and if you have any questions just let me know. Thanks
03-05-2010, 09:52 PM | #6 |
Excelent thread , if you want a more powerful booster the dual diaphram from a C20 will give more pressure for the same amount of pedal force
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
03-05-2010, 10:04 PM | #7 |
1 thing at a time is progress.
Nice write up. I have a question. I have the same prop valve. Where is the line going off of the top/front of the valve? I was going to plug mine.
Alan
Philippians 2:14-16 |
03-05-2010, 10:09 PM | #8 | |
Thanks Alan.. That line runs to the passenger side. I was going to plug it also but figured to go ahead and run it. I didn't want the big loop on the front so getting it to bend backwards, to the side, and down was the tricky part.
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 03-05-2010 at 10:29 PM. Reason: removed drivers side |
03-05-2010, 10:13 PM | #9 |
So the bottom line is going to the passenger side front, right.
Alan
03-05-2010, 10:25 PM | #10 | |
Sorry about that...
My Build "63 Stepside" Major Components 71 350 stock 86' 700R4 My Front Disc Conversion Last edited by drogers; 03-05-2010 at 10:30 PM. |
03-05-2010, 10:44 PM | #11 |
Mine didn't have any instructions.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 03-05-2010 at 10:45 PM. |
03-05-2010, 11:29 PM | #12 |
Here's a link to the doc that came with my unit... http://www.classicperform.com/Instructions/PDF/PVK.pdf
03-05-2010, 11:44 PM | #13 | |
Alan
06-28-2010, 04:32 PM | #14 |
this thread has helped me a great deal in purchasing the parts i need thanks for the great write up...
06-28-2010, 05:19 PM | #15 |
C10 CLUB Y QUE!
Great thread I like it
I'll soon do mine too |
06-28-2010, 07:54 PM | #16 |
Glad to hear it and happy to share. I've gotten a lot of great info from this site..
01-20-2012, 10:03 PM | #17 |
But Found Her 25yrs Later!
Posting here also because it's in one of the links in lolife99's "Drum to Disc" conversions 60-66 FAQ thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=443871 Pics that helped me with routing:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
