Old 10-31-2000, 10:29 AM   #1
bigd65
bigd65's Avatar
Post carb spacer
thought i'd post a message, nobody seems to want to here anymore. anyway i now have one carb spacer on my truck and have of people putting two, what will this do for performance. stock 350/holley dominator intake/ edlebrock 1406/ hypertech power coil/internal is stock.
jeff
85' C10 350/700R4
LWB with to many add-ons to type
Angleton,TX>
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 10-31-2000, 01:28 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
bigd65,
I have a four swirl hole carb spacer/adapter on my truck. The spacer made a difference on the low end torque. I can cruise at low rpms with out any problems. Currently I'm waiting for delivery of my new intake, an Eldelbrock AirGap intake. I can't wait to see how much of a difference this will make on performance. The new dual plane intake should work great. After the 305 reaches the end of its life, the intake will be fitted to a 383 Stroker. I plan on buy a crate 383 with about 400+ horses. That should plant the rubber on the street fairly well with a differential locker.
gchemist
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/index.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-31-2000, 05:34 PM   #3
Tom
driving is in my blood
Tom's Avatar
Post
A open spacer increases top end horsepower like a single plane manifold does. A 4 hole swirl spacer increases lower end-middle like a dual plane manifold. I would not put another one on if I were you.
An interesting story- When I put my new vortec heads on my truck I took it out for a spin. The low end power wasent like it used to be so I tried taking the 1" open carb spacer I had on it off. When I took it out again the low end torque was way down even farther then before! When I got back home I put the spacer back on and regained some of that low end. Wierd huh?
1978 chevy c10
383 stroker,10:1 compression,vortec heads, roller rockers,performer RPM intake, Demon 650 double pump carb, MSD ignition, headman headers, muncie four speed, 3.73 rear gears.
